An Error Message Is Displayed Indicating that the Path of a Storage Unit Is Invalid
Symptom
When you create a storage unit on eBackup, the system prompts a message indicating that the path of the storage unit is invalid. See Figure 1.
Troubleshooting
Possible causes are listed here in order of their probability.
If the fault persists after you have ruled out one cause, move on to the next one.
Possible Cause |
Solution |
A parameter is incorrectly set. |
In the Create Storage Unit window on eBackup, check whether the parameters are set correctly. If any parameter values are incorrect, correct them. The AK/SK must be the AK/SK of your account, not of an IAM user. |
The system time of eBackup is greatly different from the actual time. As a result, the response fails. |
For detailed handling measures, see The System Time of eBackup Is Greatly Different from the Actual Time. |
The network between eBackup and CBR is inaccessible. |
For detailed handling measures, see The Network Between eBackup and CBR Is Inaccessible. |
The network between eBackup and OBS is inaccessible. |
Back up data during off-peak hours or submit a service ticket. |
The version of the Virtual Disk Development Kit (VDDK) in incorrect. |
Use VDDK 6.0.3. You can download the VMware-vix-disklib-6.0.3-4888596.x86_64.tar.gz at the VMware official website: https://code.vmware.com/web/sdk/6.0/vddk. |
On the navigation bar of eBackup, choose > System Time & Zone to check whether the difference between the system time and the actual time is greater than 1 minute.
If yes, change the system time to the actual time. For details, see Configuring System Time & Zone.
Run the curl -kv https://Domain name:443 command to ping the endpoint of the region where your CBR service resides. For details about the regions and endpoints, see Regions and Endpoints.
- If the endpoint can be pinged but the problem persists, submit a service ticket.
- If the endpoint cannot be pinged, check whether the public network has been configured.
- If the public network has been configured, check whether the domain name resolution is complete by following the instructions in How Do I Test Whether Record Sets Have Taken Effect?
- If the resolution is complete but the problem persists, submit a service ticket.
- If the domain name has not been resolved, configure the correct user DNS, and run vi /etc/resolv.conf to edit the /etc/resolv.conf file. Add the DNS server IP address above the existing nameserver information. The DNS server IP address is 114.114.114.114.
Figure 3 Modifying the DNS
- If the public network has not been configured, configure it by following instructions in Planning the Network.
The Network Between eBackup and OBS Is Inaccessible
VMware backups are automatically uploaded to an OBS bucket. If the communication between eBackup and OBS is abnormal, an error will be reported.
Run the curl -kv https://Domain name:443 command to ping the endpoint of the region where your OBS service resides. For details about the regions and endpoints, see Regions and Endpoints.
- If the endpoint cannot be pinged, check whether the public network has been configured on premises.
Figure 4 Modifying the DNS
Submitting a Service Ticket
If the problem persists, submit a service ticket.
