Help Center/
Cloud Backup and Recovery/
Troubleshooting/
Failed to Import an eBackup Image Template, with an Error Displayed Indicating That the File Is Invalid
Updated on 2024-07-24 GMT+08:00
Symptom
When you import an eBackup image template during local eBackup installation, the following information is displayed: the following manifest file entry (line 1) is invalid: sha256 vmdk
Possible Cause
The VMware VM does not support the SHA256 hashing algorithm.
Solution
- Visit https://developer.vmware.com/home, download the VMware OVF Tool, and install it.
- Run the following command to convert the eBackup installation package:
ovftool.exe --shaAlgorithm=SHA1 /path/to/the/original/ebackup_xxxx.ovf /path/to/the/new/ova/ebackup-SHA1.ovf
- After the conversion is complete, install eBackup again.
