Help Center/ Object Storage Service/ User Guide (Ankara Region)/ OBS Console Operation Guide/ Event Notifications/ Application Example: Configuring SMN-Enabled Event Notification
Updated on 2024-04-16 GMT+08:00
Background Information
An enterprise has a large number of files to archive but it does not want to cost much on storage resources. Therefore, the enterprise subscribes to OBS for storing daily files and expects that an employee can be informed of every operation performed on OBS via email.
  1. Log in to OBS Console as an enterprise user.
  2. Create a bucket.
    Click Create Bucket in the upper right corner of the page. On the page, select a region, and specify a bucket name and other parameters. Then, click Create Now.
  3. Create a folder.
    Click the name of the bucket created in 2 to go to the Objects page. Then, click Create Folder. In the displayed dialog box, enter a folder name and click OK. In the following example, SMN is the folder name.
  4. In the upper left corner of the page, click and choose Simple Message Notification. On the displayed SMN page, create a topic.
    In the following example, TestTopic is the SMN topic and the notifications are sent via email.
    Use SMN to create a notification topic for OBS as follows:
    1. Create an SMN topic.
    2. Add a subscription.
    3. Modify the topic policy. On the Configure Topic Policy page, select OBS under Services that can publish messages to this topic.
    For details, see Table 1.
  5. Go back to OBS Console.
  6. Configure an event notification rule.
    1. In the bucket list, click the bucket that you have created in 2.
    2. In the navigation pane, choose Basic Configurations > Event Notification. The Event Notification page is displayed.
    3. Click Create. The Create Event Notification dialog box is displayed.
    4. Configure event notification parameters.
      After the notification is configured, an employee will be informed of all specified operations on the SMN folder in bucket testbucket.
      Table 1 Event notification parameters
      Value
      Name
      test
      Events
      ObjectCreated, ObjectRemoved
      Prefix
      SMN/
      • A folder path ends with a slash (/). Therefore, if you want to configure event notification rules for operations on folders and you need to filter folders by suffix, the suffix must also end with a slash (/).
      • If neither the Prefix nor the Suffix is configured, the event notification rule applies to all objects in the bucket.
      Notification Method
      SMN topic
      Select the project to which the SMN topic belongs.
      TestTopic
Verification
  2. Upload the test.txt file to the folder created in Step 3.
    After the file is uploaded, an employee receives an email. Keyword ObjectCreated:Post in the email indicates that the object is successfully uploaded.
  3. Delete the test.txt file uploaded in Step 2.
    After the file is successfully deleted, an employee will receive an email. Keyword ObjectRemoved:Delete in the email indicates that the object is successfully deleted.
