Viewing Basic Information of a Bucket
On OBS Console, you can view a bucket's details, including basic bucket information, process flows for common scenarios, domain name details, basic configurations, and others.
Viewing Bucket Details
- In the bucket list, click the bucket you want to operate to go to the Objects page.
 - In the navigation pane, choose Overview.
 - On the top of the page, view the bucket information, including the bucket name, region, and creation time.
Table 1 Bucket information Item
Bucket name
Name of the bucket
Region
Region where the bucket is located
Created
Creation time of the bucket
 - In the Basic Information area, view the number of objects, storage usage, bucket version, versioning status, and account ID.
Table 2 Parameters in the Basic Information area Parameter
Objects
The total number of stored folders and objects of all versions in a bucket
Used Capacity
Total storage space occupied by objects of all versions in the bucket
NOTE:If usage statistics is available for the bucket, storage usage data is not displayed here.
Bucket Version
Version number of the bucket.
Versioning
Versioning status
Account ID
Unique identity of the bucket owner. It is the same as Account ID on the My Credentials page.
 - In the Process Flow area, view the process flows for common scenarios. You can click Change Scenario in the upper right corner to choose a desired scenario.
In each flow, you can click a node to view relevant details, or click a card to navigate to the operation guide or console page.
 - In the Domain Information Details area, view information about the endpoint, access domain name, and static website hosting domain name. You can also perform related operations by clicking buttons in the Operation column.
 - In the Basic Configurations area, view the bucket's basic configurations, including lifecycle rules, static website hosting, and CORS rules. You can click a card to make required configurations.
Exporting a Bucket List
- Go to the bucket list.
 - Export all buckets. Specifically, click Export in the upper left corner of the bucket list.
 - Export the selected buckets. Specifically, select the buckets to export and click Export in the upper left corner of the bucket list.
 - Obtain the bucket list in Excel, which is automatically downloaded to your local computer.
The file lists all the buckets of the current account and includes the following information: bucket name, region, data redundancy policy, used capacity, object quantity, bucket version, and bucket creation time.
