Configuring ClickHouse SQL Inspection
Updated on 2024-11-29 GMT+08:00
You can configure rules for ClickHouse SQL inspection on FusionInsight Manager and configure rule parameters as you need.
  • The cluster client that contains the ClickHouse service has been installed in the /opt/hadoopclient directory.
  • The ClickHouse logical cluster is running properly.
  • For clusters with Kerberos authentication enabled, a service user who has the permission to operate ClickHouse tables has been created, for example, a human-machine user clickhouseuser.
  • A tenant associated with the ClickHouse service has been created and associated with the ClickHouse service user.
  • The default dynamic validity period of a rule is 1 minute.
  • Interception and blocking rules will interrupt SQL queries, so you need to set parameters of these rules properly based on the site requirements.
  • After configuring ClickHouse rules, you need to log in to the client again for the rules to take effect.
  1. Log in to FusionInsight Manager, click Cluster, and choose SQL Inspector. The SQL Inspector page is displayed.
  2. Add rules for ClickHouse by referring to Adding an SQL Inspection.
    For details about the rules supported by the ClickHouse SQL engine, see MRS SQL Inspection Rules.
    For example, add a rule whose ID is static_0008 and checks whether a SQL statement executes the cluster-level table update operation. If so, the system displays a hint.
    Figure 1 Adding a ClickHouse SQL inspection rule
  3. Log in to the node where the ClickHouse client is installed and run the following command to switch to the client installation directory.
    cd /opt/hadoopclient
    Run the following command to set environment variables:
    source bigdata_env
  4. If the current cluster is in security mode (Kerberos authentication is enabled), run the following command to authenticate the current user. The current user must have the permission to create ClickHouse tables. If the current cluster is in normal mode (Kerberos authentication is disabled), skip this step.
    kinit Component service user
    Example: kinit clickhouseuser
  5. Use the ClickHouse client to connect to the ClickHouse server.
    Security mode
    clickhouse client --host IP address of the ClickHouseServer instance --port 9440 --secure
    Normal clusters:
    clickhouse client --host IP address of the ClickHouseServer instance--user Username --password --port 9000
    Enter the password.
  6. Run the following statements to create a data table:
    CREATE DATABASE cktest ON CLUSTER default_cluster;
    CREATE TABLE cktest.test2 ON CLUSTER default_cluster ( `EventDate` DateTime, `CounterID` UInt32, `UserID` UInt32, `ver` UInt16 ) ENGINE = ReplicatedMergeTree('/clickhouse/tables/{shard}/cktest/test2', '{replica}') PARTITION BY toYYYYMM(EventDate) ORDER BY (EventDate, intHash32(UserID));
    CREATE TABLE cktest.test2_dir ON CLUSTER default_cluster as cktest.test2 ENGINE = Distributed(default_cluster, cktest, test2, rand());
  7. Run the following command to insert data to the table:
    insert into cktest.test2 values('2023-08-01',111,111,111);
    insert into cktest.test2 values('2023-08-02',222,111,111);
  8. Run the following SQL statement for the created table to check whether the rule takes effect:
    alter table cktest.test2 on cluster default_cluster update CounterID = toUInt32(222) where EventDate='2023-08-01' ;
    <Warning> SQLDefender: Distributed DDL ALTER UPDATE queries are undesirable.
    If the operation set in the rule is Intercept, the statement fails to be executed and the following information is displayed:
    DB::Exception: Distributed DDL ALTER TABLE UPDATE queries are undesirable..(QUERY_IS_PROHIBITED)
    For more ClickHouse SQL inspection rules, see MRS SQL Inspection Rules.
