ClickHouse Security Hardening
Updated on 2024-11-29 GMT+08:00
Authentication and Encryption
The authentication system of ClickHouse is as follows:
Figure 1 ClickHouse system authentication mode
  • The normal mode does not require authentication. You can use the built-in default user to log in to the system without authentication.
  • The kinit authentication mode of the client in security mode uses the sasl authentication mode. The implementation principle is as follows:
  • The client in security mode is compatible with the community version. Kerberos authentication is performed only on the server.
  • ClickHouse supports permission management for the following objects:
    Resource
    Permission
    Database
    CREATE
    Table/View
    SELECT/INSERT
    Admin
    ALL
ClickHouse does not support disabling security authentication on a cluster in security mode.
Encrypted Channel
ClickHouse enhances usability based on the open-source community version. By default, clusters in security mode use TCP and HTTP channels encrypted by OpenSSL.
Security Hardening
  • Encoding rules
    Description: The same encoding mode is used on the web service client and server to prevent garbled characters and to implement input verification.
    Security hardening: Response messages of web servers are encoded using UTF-8.
  • IP address whitelist filtering supported for management users
    Description: IP address whitelist filtering is used to prevent unauthorized clients from logging in to the system.
    Security hardening: External nodes are not allowed to access the ClickHouse client as a management user.
  • URL injection attack
    Description: A customized UI of data migration is used to prevent URL injection attacks.
    Security hardening: URL and path validity checks are implemented.
  • SQL injection attack
    Description: ClickHouse prevents SQL injection attacks.
    Security hardening: SQL statements are precompiled.
  • Log injection attack
    Description: Log injection must be prevented to avoid security information leakage.
    Security hardening: Privacy information is encrypted to prevent sensitive stack information from being recorded in logs.
  • DDoS attack
    Description: ClickHouse prevents service interruption or exceptions caused by DDoS attacks.
    Security hardening: The number of connections is configurable. The default value is 4096.
  • Anti-repudiation
    Description: Audit logs are recorded.
    Security hardening: DDL operations such as write, permission granting and revoking, and data migration are audited.
