Changing the Password for the Kerberos Administrator
It is recommended that the administrator periodically change the password of Kerberos administrator kadmin to improve the system O&M security.
If the user password is changed, the OMS Kerberos administrator password is changed as well.
You have installed the client on any node in the cluster and obtained the IP address of the node.
- Log in to the node where the client is installed as user root.
 - Run the following command to go to the client directory, for example, /opt/hadoopclient:
cd /opt/hadoopclient
 - Run the following command to set environment variables:
source bigdata_env
 - Run the following command to change the password for kadmin/admin. The password changing takes effect on all servers. Keep the password secure because it cannot be retrieved once lost.
kpasswd kadmin/admin
The password must meet the following complexity requirements by default:
- The password contains at least 8 characters.
 - The password contains at least four types of the following characters: Uppercase letters, lowercase letters, digits, spaces, and special characters which can only be ~`!?,.;-_'(){}[]/<>@#$%^&*+|\=.
 - The password cannot be the same as the username or the username spelled backwards.
 - The password cannot be a common easily-cracked passwords.
 - The password cannot be the same as the password used in the last N times. N indicates the value of Repetition Rule in Configuring Password Policies.
