On this page
Manager Log List
Updated on 2024-11-29 GMT+08:00
Log Description
Log path: The default storage path of Manager log files is /var/log/Bigdata/Manager component.
  • ControllerService: /var/log/Bigdata/controller/ (OMS installation and run logs)
  • HTTPd: /var/log/Bigdata/httpd (HTTPd installation and run logs)
  • Logman: /var/log/Bigdata/logman (log packaging tool logs)
  • NodeAgent: /var/log/Bigdata/nodeagent (NodeAgent installation and run logs)
  • okerberos: /var/log/Bigdata/okerberos (okerberos installation and run logs)
  • oldapserver: /var/log/Bigdata/oldapserver (oldapserver installation and run logs)
  • MetricAgent: /var/log/Bigdata/metric_agent (MetricAgent run logs)
  • OMM: /var/log/Bigdata/omm (OMM installation and run logs)
  • Timestamp: /var/log/Bigdata/timestamp (NodeAgent startup time logs)
  • Tomcat: /var/log/Bigdata/tomcat (Web process logs)
  • Upgrade: /var/log/Bigdata/upgrade (OMS upgrade logs)
  • UpdateService: /var/log/Bigdata/update-service (upgrade service logs)
  • Sudo: /var/log/Bigdata/sudo (sudo script execution logs)
  • OS: /var/log/message file (OS system logs)
  • OS performance: /var/log/osperf (OS performance statistics logs)
  • OS statistics: /var/log/osinfo/statistics (OS parameter configuration logs)
Log archive rule:
The automatic compression and archiving function is enabled for Manager logs. By default, when the size of a log file exceeds 10 MB, the log file is automatically compressed. The naming rule of a compressed log file is as follows: <Original log name>-<yyyy-mm-dd_hh-mm-ss>.[ID].log.zip A maximum of 20 latest compressed files are retained.
Table 1 Manager logs
Log Type
Log File Name
Controller run logs
controller.log
Log file that records component installation, upgrade, configuration, monitoring, alarm reporting, and routine O&M operations
controller_client.log
Run log file of the Representational State Transfer (REST) APIs
acs.log
ACS run log file
acs_spnego.log
spnego user logs in ACS
aos.log
AOS run log file
plugin.log
AOS plug-in logs
backupplugin.log
Run log file that records the backup and restoration operations
controller_config.log
Configuration run log file
controller_nodesetup.log
Controller loading task log file
controller_root.log
System log file of the Controller process
controller_trace.log
Log file that records the remote procedure call (RPC) communication between Controller and NodeAgent
controller_monitor.log
Monitoring log file
controller_fsm.log
State machine log file
controller_alarm.log
Controller alarm log file
controller_backup.log
Controller backup and recovery log file
install.log, restore_package.log, installPack.log, distributeAdapterFiles.log, and install_os_optimization.log
OMS installation log files
oms_ctl.log
OMS startup and stop log file
preInstall_client.log
Preprocessing log file before client installation
installntp.log
NTP installation log file
modify_manager_param.log
Manager parameter modification log file
backup.log
OMS backup script run log file
supressionAlarm.log
Alarm script run log file
om.log
OM certificate generation log file
backupplugin_ctl.log
Startup log file of the backup and restoration plug-in process
getLogs.log
Run log of the log collection script
backupAuditLogs.log
Run log of the audit log backup script
certStatus.log
Log file that records regular certificate checks
distribute.log
Certificate distribution log
ficertgenetrate.log
Certificate replacement log file, covering level-2 certificates, CAS certificates, and HTTPd certificates
genPwFile.log
Log file that records the generation of certificate password files
modifyproxyconf.log
Log file that records the modification of the HTTPd proxy configuration
importTar.log
Log file that records the process for importing certificates into the trust store.
HTTPd
install.log
HTTPd installation log file
access_log, error_log
HTTPd run log file
Logman
logman.log
Log packaging tool log file
NodeAgent
install.log and install_os_optimization.log
NodeAgent installation log file
installntp.log
start_ntp.log
NTP startup log file
ntpChecker.log
NTP check log file
ntpMonitor.log
NTP monitoring log file
heartbeat_trace.log
Log file that records heartbeats between NodeAgent and Controller
alarm.log
Alarm log file
monitor.log
Monitoring log file
nodeagent_ctl.log and start-agent.log
NodeAgent startup log file
agent.log
NodeAgent run log file
cert.log
Certificate log file
agentplugin.log
Log file that records the Agent plug-in running status
omaplugin.log
OMA plug-in run log file
diskhealth.log
Disk health check log file
supressionAlarm.log
updateHostFile.log
Host list update log file
collectLog.log
Run log file of the node log collection script
host_metric_collect.log
Run log file of host metric collection
checkfileconfig.log
Run log file of file permission check
entropycheck.log
Entropy check run log file
timer.log
Log file of scheduled node scheduling
pluginmonitor.log
Component monitoring plug-in log file
agent_alarm_py.log
Log file that records alarms upon insufficient NodeAgent file permission
checkUserThread.log
User thread usage alarm collection log file
oKerberos
addRealm.log and modifyKerberosRealm.log
Realm handover log file
checkservice_detail.log
Okerberos health check log file
genKeytab.log
keytab generation log file
KerberosAdmin_genConfigDetail.log
Run log file of kadmin.conf generated during start of the kadmin process
KerberosServer_genConfigDetail.log
Run log file of krb5kdc.conf generated during start of the krb5kdc process
oms-kadmind.log
Run log file of the kadmin process
oms_kerberos_install.log and postinstall_detail.log
Okerberos installation log file
oms-krb5kdc.log
Run log file of the krbkdc process
start_detail.log
Okerberos startup log file
realmDataConfigProcess.log
Log file that records the rollback upon a realm handover failure
stop_detail.log
Okerberos stop log file
oldapserver
ldapserver_backup.log
Oldapserver backup log file
ldapserver_chk_service.log
Oldapserver health check log file
ldapserver_install.log
Oldapserver installation log file
ldapserver_start.log
Oldapserver startup log file
ldapserver_status.log
Log file that records the status of the Oldapserver process
ldapserver_stop.log
Oldapserver stop log file
ldapserver_wrap.log
Oldapserver service management log file
ldapserver_uninstall.log
Oldapserver uninstallation log file
restart_service.log
Oldapserver restart log file
ldapserver_unlockUser.log
Log file that records information about unlocking LDAP users and managing accounts
metric_agent
gc.log
MetricAgent JVM GC log file
metric_agent.log
Run log file of MetricAgent
metric_agent_qps.log
Log file that records MetricAgent Internal queue length and QPS information
metric_agent_root.log
All run log files of MetricAgent
start.log
Log file that records information about the MetricAgent startup and stop
OMM
omsconfig.log
OMS configuration log file
check_oms_heartbeat.log
OMS heartbeat log file
monitor.log
OMS monitoring log file
ha_monitor.log
HA_Monitor operation log file
ha.log
HA operation log file
fms.log
Alarm log file
fms_ha.log
HA alarm monitoring log file
fms_script.log
Alarm control log file
config.log
Alarm configuration log file
iam.log
IAM log file
iam_script.log
IAM control log file
iam_ha.log
IAM HA monitoring log file
config.log
IAM configuration log file
operatelog.log
IAM operation log file
heartbeatcheck_ha.log
OMS heartbeat HA monitoring log file
install_oms.log
pms_ha.log
pms_script.log
Monitoring control log file
config.log
Monitoring configuration log file
plugin.log
Monitoring plug-in run log file
pms.log
Monitoring log file
ha.log
HA run log file
omm_gaussdba.log
GaussDB HA monitoring log file
gaussdb-<SERIAL>.log
GaussDB run log file
gs_ctl-<DATE>.log
Archive log file of GaussDB control logs
gs_ctl-current.log
GaussDB control log file
gs_guc-current.log
GaussDB operation log file
encrypt.log
OMM encryption log file
omm_agent_ctl.log
OMA control log file
oma_monitor.log
OMA monitoring log file
install_oma.log
OMA installation log file
config_oma.log
OMA configuration log file
omm_agent.log
OMA run log file
acs.log
ACS resource log file
aos.log
AOS resource log file
controller.log
Controller resource log file
floatip.log
Floating IP address resource log file
ha_ntp.log
NTP resource log file
httpd.log
HTTPd resource log file
okerberos.log
Okerberos resource log file
oldap.log
OLdap resource log file
tomcat.log
Tomcat resource log file
send_alarm.log
Run log file of the HA alarm sending script of the management node
pms_gc_<DATE>.log
Monitoring GC log file
pms_jstack.log
Monitoring stack log file
Timestamp
restart_stamp
NodeAgent startup time log file
Tomcat
cas.log and localhost_access_cas_log.log
CAS run log file
catalina.log, catalina.out, host-manager.log, localhost.log, and manager.log
Tomcat run log file
localhost_access_web_log.log
Log file that records the access to REST APIs of FusionInsight Manager
web.log
Run log file of the Web process
northbound_ftp_sftp.log, snmp.log
Northbound log file
perfStats.log
Performance statistics log file
redis_script.log
Redis script run log file
web_redis.log
Run log file of Redis-ws
update-service
omm_upd_server.log
UPDServer run log file
omm_upd_agent.log
UPDAgent run log file
update-manager.log
UPDManager run log file
install.log
Installation log file of the upgrade service
uninstall.log
Uninstallation log file of the upgrade service
catalina.<Time>.log, catalina.out, host-manager.<Time>.log, localhost.<Time>.log, manager.<Time>.log, manager_access_log.<Time>.txt, web_service_access_log.<Time>.txt, catalina.log, gc-update-service.log.0.current, update-manager.controller, update-web-service.controller, update-web-service.log, commit_rm_distributed.log, commit_rm_upload_package.log, common_omagent_operator.log, forbid_monitor.log, initialize_package_atoms.log, initialize_unzip_pack.log, omm-upd.log, register_patch_pack.log, resume_monitor.logrollback_clear_patch.log, unregister_patch_pack.log, update-rcommupd.log, update-rcupdatemanager.log, and update-service.log
Run log file of the upgrade service
Upgrade
upgrade.log_<Time>
OMS upgrade log file
rollback.log_<Time>
OMS rollback log file
sudo
sudo.log
Sudo script execution log file
Log Levels
Table 2 describes the log levels provided by Manager. The log levels are FATAL, ERROR, WARN, INFO, and DEBUG in descending order. Logs whose levels are higher than or equal to the set level are printed by the program. The number of printed logs decreases as the set log level increases.
Table 2 Log levels
Level
FATAL
Logs of this level record fatal error information about the current event processing that may result in a system crash.
ERROR
Logs of this level record error information about the current event processing, which indicates that system running is abnormal.
WARN
Logs of this level record abnormal information about the current event processing. These abnormalities will not result in system faults.
INFO
Logs of this level record normal running status information about the system and events.
DEBUG
Logs of this level record system information and debugging information.
Log Formats
The following table lists the Manager log formats.
Table 3 Log formats
Log Type
Component
Format
Example
Controller, HTTPd, Logman, NodeAgent, oKerberos, oldapserver, OMM, Tomcat, and upgrade
<yyyy-MM-dd HH:mm:ss, SSS>|<Log Level>|<Name of the thread for which the log is generated>|<Log message>|<Location where the log event occurs>
2020-06-30 00:37:09,067 INFO [pool-1-thread-1] Completed Discovering Node. com.xxx.hadoop.om.controller.tasks.nodesetup.DiscoverNodeTask.execute(DiscoverNodeTask.java:299)
