Updating the Configuration of an Installed Client
The cluster provides a client for you to connect to a server, view task results, or manage data. If you modify service configuration parameters on FusionInsight Manager and restart the service, you need to download and install the installed client again or use the configuration file to update the client.
You have installed a client.
Method 1:
 - In the upper right corner of the home page, click Download Client and set Type to Configuration Files Only.
The generated compressed file contains the configuration files of all services.
     The cluster supports two types of clients: x86_64 and aarch64. The client type must match the architecture of the node for installing the client. Otherwise, client installation will fail.
 - Select the path for saving the downloaded client configuration file.
- Server: Download the file to the active OMS node of the cluster.
The generated file is stored in the /tmp/FusionInsight-Client directory on the active OMS node by default. You can also store the client file in other directories, and user omm has the read, write, and execute permissions on the directory. If the client file already exists in the path, the existing client file will be replaced.
       When a cluster has many services installed, the cluster client file becomes quite large. Additionally, decompressing this file during installation can consume significant disk space. It's recommended to download the client files to a different directory that has ample space, or to promptly remove unnecessary files from the client download directory after installation. Doing so helps avoid exhausting the /tmp directory's disk space, which could interrupt the normal operation of the cluster nodes.
After the file is generated, copy the obtained package to another directory, for example, /opt/Bigdata/hadoopclient, as user omm or client installation user.
 - Browser: Download the file to the local computer.
 - Remote node: Download the file to a node other than the active OMS node. If you select this option, you need to set the following parameters:
Table 1 Parameters Parameter
Example Value
Save to Path
Path for storing client files.
If there is already a client file in the path, it will be overwritten. For a remote node, write permission for the path is required.
/tmp/FusionInsight-Client-Remote/
Host IP Address
IP address of the remote node.
NOTE:The platform type of the remote node must be the same as that of the downloaded client. Otherwise, the client may fail to be installed.
x.x.x.x
Host Port
Host port of the remote node.
22
Username
Username for logging in to the remote node.
xxx
Authentication Method
You can choose one of the following methods:
- Password: Use the password for login.
 - SSH private keys: Use SSH private keys for login.
 - None: To use this method, passwordless login needs to be enabled for the node.
Password
Password
This parameter is mandatory when Authentication Method is set to Password.
This parameter indicates the password used for login.
xxx
SSH Private Keys
This parameter is mandatory when Authentication Method is set to SSH private keys.
Click Select File and select a local file to upload.
Auto Deployment
Whether to enable auto deployment. This parameter is mandatory when Select Client Type is set to Complete Client.
- If you set this parameter to yes, the client is automatically installed and deployed on the current node.
 - If you set this parameter to no, the client will not be automatically installed and deployed. You need to manually install the client after it is downloaded.
Yes
Deployment Path
This parameter is mandatory when Auto Deployment is set to Yes. If only the configuration file is downloaded, this parameter will not be displayed.
The deployment path must be empty if it already exists on the remote node. Otherwise, it will be created automatically. The path also requires operate and write permissions.
/opt/testclient
 - Use WinSCP to save the compressed file to the installation directory of the client as the client installation user, such as /opt/hadoopclient.
 - Decompress the software package.
Run the following commands to go to the directory where the client is installed, and decompress the file to a local directory. For example, the downloaded client file is FusionInsight_Cluster_1_Services_Client.tar.
cd /opt/hadoopclient
tar -xvf FusionInsight_Cluster_1_Services_Client.tar
 - Verify the software package.
Run the following command to verify the decompressed file and check whether the command output is consistent with the information in the sha256 file:
sha256sum -c FusionInsight_Cluster_1_Services_ClientConfig_ConfigFiles.tar.sha256
FusionInsight_Cluster_1_Services_ClientConfig_ConfigFiles.tar: OK
 - Decompress the package to obtain the configuration file.
tar -xvf FusionInsight_Cluster_1_Services_ClientConfig_ConfigFiles.tar
 - Run the following command in the client installation directory to update the client using the configuration file:
sh refreshConfig.sh Client installation directory Directory where the configuration file is located
For example, run the following command:
sh refreshConfig.sh /opt/hadoopclient /opt/hadoopclient/FusionInsight_Cluster_1_Services_ClientConfig_ConfigFiles
If the following information is displayed, the configurations have been updated successfully:
Succeed to refresh components client config.
Method 2:
- Log in to the node where the client is installed as user root.
 - Go to the client installation directory, for example, /opt/client, and run the following commands to update the configuration file:
cd /opt/client
sh autoRefreshConfig.sh
 - Enter the username and password of the FusionInsight Manager administrator and the floating IP address of FusionInsight Manager. You can run the ifconfig command on the active OMS node to view the floating IP address.
 - Enter the names of the components whose configurations need to be updated. Use commas (,) to separate the component names. Press Enter to update the configurations of all components if necessary.
