Help Center/
      MapReduce Service/
        User Guide (Ankara Region)/
        FusionInsight Manager Operation Guide/
        Tenant Resources/
        Using the Capacity Scheduler/
        Managing Resources/
      Modifying a Resource Pool
        Updated on 2024-11-29 GMT+08:00
When hosts in a resource pool need to be adjusted based on service requirements, you can modify members in the resource pool on FusionInsight Manager.
 - Choose .
 - In the resource pool list, locate the row containing the specified resource pool, and click Modify in the Operation column.
 - In the Resource area, modify hosts.
- Adding hosts: Select desired hosts in Available Hosts and click
 to add them to the resource pool. - Deleting hosts: Select desired hosts in Selected Hosts and click
 to remove them from the resource pool. The host list in the resource pool can be left blank.
 - Click OK.
   Parent topic: Managing Resources
