On this page
Configuring Audit Log Dumping
Updated on 2024-11-29 GMT+08:00
The audit logs of FusionInsight Manager are stored in the database by default. If the audit logs are retained for a long time, the disk space of the data directory may be insufficient. To store audit logs to another archive server, administrators can set the required dump parameters to automatically dump these logs. This facilitates the management of audit logs.
If you do not configure the audit log dumping, the system automatically saves the audit logs to a file when the number of audit logs reaches 100,000 pieces. The save path is ${BIGDATA_DATA_HOME} /dbdata_om/dumpData/iam/operatelog on the active management node. The file name format is OperateLog_store_YY_MM_DD_HH_MM_SS.csv. The maximum number of historical audit log files is 50.
  2. Choose Audit > Configuration.
  3. Click the switch on the right of Audit Log Dumping Flag.
    Audit Log Dump is disabled by default. If is displayed, Audit Log Dump is enabled.
  4. Set the dump parameters based on information provided in Table 1
    Table 1 Audit log dump parameters
    Value
    SFTP IP Mode
    Mode of the destination IP address. The value can be IPv4 or IPv6.
    IPv4
    SFTP IP
    SFTP server for storing dumped audit logs. You are advised to use the SFTP service based on SSH v2 to prevent security risks.
    192.168.10.51 (example value)
    SFTP Port
    Connection port of the SFTP server for storing dumped audit logs
    22 (example value)
    Save Path
    Path for storing audit logs on the SFTP server
    /opt/omm/oms/auditLog (example value)
    SFTP Username
    User name for logging in to the SFTP server
    root (example value)
    SFTP Password
    Password for logging in to the SFTP server
    Password for logging into the SFTP server
    SFTP Public key
    Specifies the public key of the SFTP server. This parameter is optional. You are advised to set the public key of the SFTP server. Otherwise, security risks may exist.
    Dumping Mode
    Dump mode. Value options are as follows:
    • By Quantity: If the number of pieces of logs reaches the value of this parameter (100000 by default), the logs are dumped.
    • By Time: specifies the date when logs are dumped. The dumping frequency is once a year.
    • By Quantity
    • By Time
    Dumping Date
    This parameter is available only when Dumping Mode is set to By time. After you select a dump date, the system starts dumping on this date. The logs to be dumped include all the audit logs generated before January 1 00:00 of the current year.
    11-06
    If the SFTP public key is empty, the system displays a security risk warning. Evaluate the security risk and then save the configuration.
  5. Click OK to complete the settings.
    Key fields in the audit log dump file are as follows:
    • USERTYPE indicates the user type. Value 0 indicates a human-machine user, and value 1 indicates a machine-machine user.
    • LOGLEVEL indicates the security level. Value 0 indicates Critical, value 1 indicates Major, value 2 indicates Minor, and value 3 indicates Warning.
    • OPERATERESULT indicates the operation result. Value 0 indicates that the operation is successful, and value 1 indicates that the operation is failed.
