Creating a Backup Task
You can create backup tasks on FusionInsight Manager. Executing backup tasks backs up related data.
 - Choose O&M > Backup and Restoration > Backup Management. On the page that is displayed, click Create.
 - Set Backup Object to OMS or the cluster whose data you want to back up.
 - Enter a task name in the Name text box.
 - Set Mode to Periodic or Manual as required.
Table 1 Backup types Type
Periodic backup
Start Time
Indicates the time when a periodic backup task is started for the first time.
Period
Task execution interval. Value options are Hours and Days.
Backup Policy
The following policies can be selected:
- Full backup at the first time and subsequent incremental backup
 - Full backup every time
 - Full backup once every n times
Manual backup
N/A
You need to manually execute the task to back up data.
 - Set required parameters in the Configuration area.
- Metadata and service data can be backed up.
 - For details about how to back up data of different components, see Backup and Recovery Management.
 - Click OK to save the configurations.
 - In the backup task list, you can view the created backup task.
Locate the row that contains the target backup task, choose More > Back Up Now in the Operation column to execute the task immediately.
