Overview
Overview
Log in to FusionInsight Manager and choose Cluster > Services > KrbServer. On the displayed page, click Instance. The instance management page is displayed, including the function area and role instance list.
Functional Area
After selecting the instances to be operated in the function area, you can maintain and manage the role instances, such as starting or stopping the instances. Table 1 shows the main operations.
        UI Portal  |
        Description  |
        Start Instance  |
        Start a specified instance in the cluster. You can start a role instance in the Not Started, Stop Failed, or Startup Failed state to use the role instance.  |
        Stop a specified instance in the cluster. You can stop a role instance that is no longer used or is abnormal.  |
        Restart a specified instance in the cluster. You can restart an abnormal role instance to restore it.  |
        Restart a specified instance in the cluster without interrupting services. For details about the parameter settings, see Performing a Rolling Restart of a Cluster.  |
        Recommission or decommission a specified instance in the cluster to change the service availability status of the service. For details, see Decommissioning and Recommissioning an Instance.
         Only the role DataNode in HDFS, role NodeManager in Yarn, role EsNode in Elasticsearch, and role ClickHouseServer in ClickHouse, and role RegionServer in HBase support the recommissioning and decommissioning functions.  |
        Desired instance > More > Synchronize Configuration  |
        If the Configuration Status of a role instance is Expired, the role instance has not been restarted after the configuration is modified, and the new configuration is saved only on FusionInsight Manager. In this case, use this function to deliver the new configuration to the specified instance.
        Desired instance > Instance Configurations  |
        For details, see Managing Instance Configurations.  |
You can filter instances based on the role they belong to or their running status in the function area.
   Click Advanced Search to search for specified instances by specifying other filter criteria, such as Host Name, Management IP Address, Business IP Address, or Instance Groups.
Role Instance List
The role instance list contains the instances of all roles in the cluster. The list displays the running status, configuration status, hosts, and related IP addresses of each instance.
        Status  |
        Description  |
        Normal  |
        Indicates that the instance is running properly.  |
        Faulty  |
        Indicates that the instance cannot run properly.  |
        Decommissioned  |
        Indicates that the instance is out of service.  |
        Not started  |
        Indicates that the instance is stopped.  |
        Unknown  |
        Indicates that the initial status of the instance cannot be detected.  |
        Starting  |
        Indicates that the instance is being started.  |
        Stopping  |
        Indicates that the instance is being stopped.  |
        Restoring  |
        Indicates that an exception may occur in the instance and the instance is being automatically rectified.  |
        Decommissioning  |
        Indicates that the instance is being decommissioned.  |
        Recommissioning  |
        Indicates that the instance is being recommissioned.  |
        Failed to start  |
        Indicates that the service fails to be started.  |
        Failed to stop  |
        Indicates that the service fails to be stopped.  |
Instance Details
You can click an instance name to go to the instance details page and view the basic information, configuration file, instance logs, and monitoring metric reports of the instance.
