Help Center/
      MapReduce Service/
        User Guide (Ankara Region)/
        FusionInsight Manager Operation Guide/
        Cluster/
        Managing a Service/
        Other Service Management Operations/
      Performing Active/Standby Switchover of a Role Instance
        Updated on 2024-11-29 GMT+08:00
Some service roles are deployed in active/standby mode. If the active instance needs to be maintained and cannot provide services, or other maintenance is required, you can manually trigger an active/standby switchover.
 - Choose Cluster > Services.
 - Click the specified service name on the service management page.
 - On the service details page, expand the More drop-down list and select Perform Role Instance Switchover.
 - In the displayed dialog box, enter the password of the current login user and click OK.
 - In the displayed dialog box, click OK to perform active/standby switchover for the role instance.
     - The Manager component package only supports the active/standby switchover of DBService role instances.
 - The HD component package supports active/standby switchover of the following service role instances: HDFS, Yarn, HBase, and MapReduce.
 - When an active/standby switchover is performed for a NameNode on HDFS, a NameService must be set.
 - The Porter component package only supports the active/standby switchover of Loader role instances.
 - The RTD component package supports active/standby switchover of RTDService and MOTService role instances.
 - This function cannot be used for other role instances.
   Parent topic: Other Service Management Operations
