Managing Monitoring Metric Reports
On FusionInsight Manager, you can customize the cluster monitoring items to be displayed in the Cluster area on the home page and export monitoring data.
  The interval on the horizontal axis of the chart varies depending on the time period you specify. Data monitoring rules are as follows:
- 0 to 21 hours and 20 minutes: The interval is 5 minutes. The cluster must have been installed for at least 10 minutes, and monitoring data of a maximum of 90 days is saved.
 - 21 hours and 20 minutes to 128 hours: The interval is 30 minutes. The cluster must have been installed for at least 30 minutes, and monitoring data of a maximum of 90 days is saved.
 - 128 to 256 hours: The interval is 1 hour. The cluster must have been installed for at least 1 hour, and monitoring data of a maximum of 90 days is saved.
 - 256 hours to 256 days: The interval is 1 day. The cluster must have been installed for at least 1 day, and monitoring data of a maximum of 90 days is saved.
 - If the disk usage of the partition where GaussDB resides exceeds 80%, real-time monitoring data and monitoring data whose interval is 5 minutes will be deleted.
 - Storage resources (HDFS) in Tenant Resources (0 to 300 hours): The interval is 1 hour. The cluster must have been installed for at least 1 hour, and monitoring data of a maximum of 3 months is saved.
Customizing a Monitoring Metric Report
 - Choose Homepage.
 - In the upper right corner of the Cluster area, click
 and choose Customize from the displayed menu.
     Monitoring data of the past 1 hour is displayed at an interval of 5 minutes. After you enter the Real-time Monitoring page, you can view that real-time monitoring data is displayed on the right of the monitoring chart at an interval of 5 minutes.
 - In the left pane of the Customize Statistics dialog box, select a resource to monitor.
 - Select one or multiple monitoring metrics in the right pane.
 - Click OK.
Exporting All Monitoring Data
 - Choose Homepage.
 - In the upper right corner of the Cluster area, select a time range to obtain monitoring data, for example, 1w.
Real-time data is displayed by default, which cannot be exported. You can click
 to customize a time range. - In the upper right corner of the Cluster area, click
 and choose Export from the displayed menu.
Exporting Monitoring Data of a Specified Monitoring Item
 - Choose Homepage.
 - In the upper right corner of any monitoring report pane in the Cluster area, click
. - Select a time range to obtain monitoring data, for example, 1w.
 to customize a time range. - Click Export.
