Log Structuring
Log data can be structured or unstructured. Structured data is quantitative data or can be defined by unified data models. It has a fixed length and format. Unstructured data has no pre-defined data models and cannot be fit into two-dimensional tables of databases.
During log structuring, logs with fixed or similar formats are extracted from a log stream based on your defined structuring method and irrelevant logs are filtered out.
Precautions
- You have created a log stream.
- Log structuring is recommended when most logs in a log stream share a similar pattern.
Creating a Structuring Rule
Add structuring rules to a log stream and LTS will extract logs based on the rules.
To structure logs:
- Log in to the LTS console and choose Log Management in the navigation pane on the left.
- Select a log group and a log stream.
- On the log stream details page, click
in the upper right corner. On the page displayed, select Log Structuring to structure logs.
- If a structured field exceeds 20 KB, only the first 20 KB is retained.
- The following system fields cannot be extracted during log structuring: groupName, logStream, lineNum, content, logContent, logContentSize, collectTime, category, clusterId, clusterName, containerName, hostIP, hostId, hostName, nameSpace, pathFile, and podName.
- Click Save.
Modifying a Structuring Rule
To modify a structuring rule, perform the following steps:
- On the Log Structuring page, click
to modify a structuring rule.
You can modify the structuring rules, including the structuring mode, log extraction field, and tag field.
- Click Save.
Deleting a Structuring Rule
If a log structuring rule is no longer used, perform the following steps to delete it:
to delete a structuring rule. - In the displayed dialog box, click OK.
Deleted structuring rules cannot be restored. Exercise caution when performing this operation.
