Transferring Logs to OBS
Updated on 2024-04-12 GMT+08:00
You can transfer logs to OBS and download log files from the OBS console.
To transfer logs, you must have the OBS Administrator permissions apart from the LTS permissions.
  • Logs have been ingested to LTS.
  • You have created an OBS bucket.
Creating a Log Transfer Task
  1. Log in to the LTS console and choose Log Transfer in the navigation pane on the left.
  2. Click Configure Log Transfer in the upper right corner.
  3. On the displayed page, configure the log transfer parameters.
    After a transfer task is created, you can modify parameters except the log group name, transfer destination, and log stream name.
    Table 1 Transfer parameters
    Example Value
    Enable Transfer
    Enabled by default.
    Enabled
    Transfer Destination
    Select a cloud service for log transfer.
    OBS
    Log Group Name
    Select a log group.
    N/A
    Log Stream Name
    Select a log stream.
    N/A
    OBS Bucket
    • Select an OBS bucket.
      • If no OBS buckets are available, click View OBS Bucket to access the OBS console and create an OBS bucket.
    • Currently, LTS supports only Standard OBS buckets.
    N/A
    Custom Log Transfer Path
    • Enabled: Logs will be transferred to a custom path to separate transferred log files of different log streams.
      The format is /LogTanks/Region name/Custom path. The default custom path is lts/%Y/%m/%d, where %Y indicates the year, %m indicates the month, and %d indicates the day. A custom path must meet the following requirements:
      • Must start with /LogTanks/Region name.
      • Can contain only letters, digits, and the following special characters: &$@;:,=+?-._/ %. The character % can only be followed only by Y (year), m (month), d (day), H (hour), and M (minute). Any number of characters can be added before and after %Y, %m, %d, %H, and %M, and the sequence of these variables can be changed.
      • Can contain 1–128 characters.
      Example:
      1. If you enter LTS-test/%Y/%m/%done/%H/%m, the path is LogTanks/Region name/LTS-test/Y/m/done/H/m/Log file name.
      2. If you enter LTS-test/%d/%H/%m/%Y, the path is LogTanks/Region name/LTS-test/d/H/m/Y/Log file name.
    • Disabled: Logs will be transferred to the default path. The default path is LogTanks/Region name/2019/01/01/Log group/Log stream/Log file name.
    Log Prefix
    The file name prefix of the log files transferred to an OBS bucket
    The prefix must meet the following requirements:
    • Can contain 0 to 64 characters.
    • Can contain only letters, digits, hyphens (-), underscores (_), and periods (.).
    Example: If you enter LTS-log, the log file name will be LTS-log_Log file name.
    LTS-log
    Format
    The storage format of logs. The value can be Raw Log Format or JSON.
    • Examples of the raw log format:
      (Logs displayed on the LTS console are in the raw format.)
      Sep 30 07:30:01 ecs-bd70 CRON[3459]: (root) CMD (/opt/oss/servicemgr/ICAgent/bin/manual/mstart.sh > /dev/null 2>&1)
    • The following is an example of the JSON format:
      {"host_name":"ecs-bd70","ip":"192.168.0.54","line_no":249,"message":"Sep 30 14:40:01 ecs-bd70 CRON[4363]: (root) CMD (/opt/oss/servicemgr/ICAgent/bin/manual/mstart.sh > /dev/null 2>&1)\n","path":"/var/log/syslog","time":1569825602303}
    Json
    Log Transfer Interval
    The interval for automatically transferring logs to OBS buckets. The value can be 2, 5, or 30 minutes, or 1, 3, 6, or 12 hours.
    3 hours
    Time Zone
    When logs are transferred to OBS buckets, the time in the transfer directory and file name will use the specified UTC time zone.
    (UTC) Coordinated Universal Time
    Filter by Tag Fields
    During transfer, logs will be filtered by tag fields collected by ICAgent.
    • Disabled: Logs will not be filtered by tag fields.
    • Enabled: Default tag fields include those for hosts (hostIP, hostId, hostName, pathFile, and collectTime) and for Kubernetes (clusterName, clusterId, nameSpace, podName, containerName, and appName). Optional public tag fields are regionName, logStreamName, logGroupName, and projectId.
      When Filter by Tag Fields is enabled, Format must be JSON.
    • Filter by Tag Fields: When this parameter is enabled, logs will be filtered by tags.
    Enabled
  4. Click OK. When the log transfer status changes to Normal, the transfer task has been created.
  5. Click the OBS bucket name in the Transfer Destination column to switch to the OBS console and view the transferred log files.
    Transferred logs can be downloaded from OBS to your local computer for viewing.
    Logs stored in OBS are in raw or JSON format.
Modifying a Log Transfer Task
  1. Locate the row that contains the target transfer task and click Modify in the Operation column.
  2. Click OK.
Viewing Transfer Details
  1. Locate the target log transfer task and click Details in the row of the desired task to view the task details.
  2. On the displayed Transfer Details page, you can view the log transfer details.
Deleting a Log Transfer Task
If logs do not need to be transferred, you can delete the transfer task.
  • After a transfer task is deleted, log transfer will be stopped. Exercise caution when performing the deletion.
  • After a transfer task is deleted, the logs that have been transferred remain in OBS.
  • When you create a transfer task, OBS will grant read and write permissions to LTS for the selected bucket. If one OBS bucket is used by multiple transfer tasks, perform the following operations to delete the transfer task:
    • If only one transfer task is created using this OBS bucket, delete the bucket access permission granted to specific users on the Access Control > Bucket ACLs tab page on the OBS console when you delete the transfer task.
    • If multiple transfer tasks are created using this OBS bucket, do not delete the bucket access permission. Otherwise, data transfer will fail.
  1. Locate the row of the target transfer task and choose Delete in the Operation column.
  2. Click OK.
Viewing Transfer Status
The status of a transfer task can be Normal, Abnormal, or Disabled.
  • Normal: The log transfer task works properly.
  • Abnormal: An error occurred in the log transfer task. The possible causes are as follows:
    • The OBS bucket has been deleted. Specify another OBS bucket.
    • Access control on the OBS bucket is configured incorrectly. Access the OBS console to correct the settings.
    • The key for the encrypted OBS bucket has been deleted or the authorization has been canceled. Ensure that the key is valid.
  • Disabled: The log transfer task is stopped.
