ICAgent Statuses
The following table lists the ICAgent statuses.
Status |
Description |
Running |
ICAgent is running properly. |
Uninstalled |
ICAgent is not installed. |
Installing |
ICAgent is being installed. This process takes about one minute. |
Installation failed |
ICAgent installation failed. |
Upgrading |
ICAgent is being upgraded. This process takes about one minute. |
Upgrade failed |
ICAgent upgrade failed. |
Offline |
ICAgent is abnormal because the Access Key ID/Secret Access Key (AK/SK) pair is incorrect. Obtain the correct AK/SK pair and install ICAgent again. |
Faulty |
ICAgent is faulty. Contact technical support. |
Uninstalling |
ICAgent is being uninstalled. This process takes about one minute. |
Authentication error |
Authentication fails because parameters were incorrectly configured during ICAgent installation. |
Restricted |
The LTS license is restricted. Check the license and update it in a timely manner. |
