Permissions Management
If you need to assign different permissions to employees in your enterprise to access your LTS resources, Identity and Access Management (IAM) is a good choice for fine-grained permissions management. IAM provides identity authentication, permissions management, and access control, helping you secure access to your LTS resources.
With IAM, you can use your account to create IAM users for your employees, and assign permissions to the users to control their access to LTS resources. For example, some software developers in your enterprise need to use LTS resources but should not delete them or perform other high-risk operations. In this case, you can create IAM users for the software developers and grant them only the permissions required.
If your account does not require individual IAM users for permissions management, you can skip this section.
IAM is a free service. You only pay for the resources in your account. For more information about IAM, see section "Service Overview" in the Identity and Access Management User Guide.
LTS Permissions
By default, new IAM users do not have permissions assigned. You need to add users to one or more groups, and attach permissions policies or roles to these groups. Users inherit permissions from the groups to which they are added and can perform specified operations on cloud services based on the permissions.
LTS is a project-level service deployed and accessed in specific physical regions. To assign LTS permissions to a user group, specify the scope as region-specific projects and select projects for the permissions to take effect. If All projects is selected, the permissions will take effect for the user group in all region-specific projects. When accessing LTS, the users need to switch to a region where they have been authorized to use LTS.
Policies: A type of fine-grained authorization mechanism that defines permissions required to perform operations on specific cloud resources under certain conditions. This mechanism allows for more flexible policy-based authorization, meeting requirements for secure access control. For example, you can grant Elastic Cloud Server (ECS) users only the permissions for managing a certain type of ECSs. Most policies define permissions based on APIs.
The system permissions supported by LTS are listed in Table 1.
Name |
Description |
Type |
Dependency |
LTS FullAccess |
Full permissions for LTS. Users with these permissions can perform operations on LTS. |
System-defined policy |
OBS Administrator and AOM FullAccess |
LTS ReadOnlyAccess |
Read-only permissions for LTS. Users with these permissions can only view LTS data. |
LTS Administrator |
Administrator permissions for LTS. |
This role is dependent on the Tenant Guest and Tenant Administrator roles. |
LTS Admin |
System-defined role |
Table 2 lists the common operations supported by each system-defined policy and role of LTS. Choose the appropriate policies and roles according to this table.
Operation |
LTS FullAccess |
LTS Administrator |
Querying a log group |
Creating a log group |
Modifying a log group |
Deleting a log group |
Querying a log stream |
Creating a log stream |
Modifying a log stream |
Deleting a log stream |
Configuring log collection from hosts |
Querying the configuration of log structuring |
Configuring log structuring |
Enabling quick analysis |
Disabling quick analysis |
Querying a filter |
Disabling a filter |
Enabling a filter |
Deleting a filter |
Viewing a log transfer task |
Creating a log transfer task |
Modifying a log transfer task |
Deleting a log transfer task |
Enabling a log transfer task |
Disabling a log transfer task |
Installing ICAgent |
Upgrading ICAgent |
Uninstalling ICAgent |
To use a custom fine-grained policy, log in to IAM as the administrator and select fine-grained permissions of LTS as required.
Table 3 describes fine-grained permission dependencies of LTS.
Permission |
Description |
Dependency |
lts:agents:list |
List agents |
None |
lts:buckets:get |
Get bucket |
None |
lts:groups:put |
Put log group |
None |
lts:transfers:create |
Create transfer |
obs:bucket:PutBucketAcl obs:bucket:GetBucketAcl obs:bucket:GetEncryptionConfiguration obs:bucket:HeadBucket dis:streams:list dis:streamPolicies:list |
lts:groups:get |
Get log group |
None |
lts:transfers:put |
Put transfer |
lts:resourceTags:delete |
Delete resource tag |
None |
lts:ecsOsLogPaths:list |
List ecs os logs paths |
None |
lts:structConfig:create |
Create struct config |
None |
lts:agentsConf:get |
Get agent conf |
None |
lts:logIndex:list |
Get log index |
None |
lts:transfers:delete |
Delete transfer |
None |
lts:regex:create |
Create struct regex |
None |
lts:subscriptions:delete |
Delete subscription |
None |
lts:overviewLogsLast:list |
List overview last logs |
None |
lts:logIndex:get |
Get log index |
None |
lts:sqlalarmrules:create |
Create alarm options |
None |
lts:agentsConf:create |
Create agent conf |
None |
lts:sqlalarmrules:get |
Get alarm options |
None |
lts:datasources:batchdelete |
Batch delete datasource |
None |
lts:structConfig:put |
Update struct config |
None |
lts:groups:list |
List log groups |
None |
lts:sqlalarmrules:delete |
Delete alarm options |
None |
lts:transfers:action |
Enabled transfer |
None |
lts:datasources:post |
Post datasource |
None |
lts:topics:create |
Create log topic |
None |
lts:resourceTags:get |
Query resource tags |
None |
lts:filters:put |
Update log filter |
None |
lts:logs:list |
List logs |
None |
lts:subscriptions:create |
Create subscription |
None |
lts:filtersAction:put |
Put log filter action |
None |
lts:overviewLogsTopTopic:get |
List overview top logs |
None |
lts:datasources:put |
Put datasource |
None |
lts:structConfig:delete |
Delete struct config |
None |
lts:logIndex:delete |
Deleting a specified log index |
None |
lts:filters:get |
Get log filter |
None |
lts:topics:delete |
Delete log topics |
None |
lts:agentSupportedOsLogPaths:list |
List agent supported os logs paths |
None |
lts:topics:put |
Put log topic |
None |
lts:agentHeartbeat:post |
Post agent heartbeat |
None |
lts:logsByName:upload |
Upload logs by name |
None |
lts:buckets:list |
List buckets |
None |
lts:logIndex:post |
Create log index |
None |
lts:logContext:list |
List logs context |
None |
lts:groups:delete |
Delete log group |
None |
lts:filters:delete |
Delete log filter |
None |
lts:resourceTags:put |
Update resource tags |
None |
lts:structConfig:get |
Get struct config |
None |
lts:overviewLogTotal:get |
Get overview logs total |
None |
lts:subscriptions:put |
Put subscription |
None |
lts:subscriptions:list |
List subscription |
None |
lts:datasources:delete |
Delete datasource |
None |
lts:transfersStatus:get |
List transfer status |
None |
lts:logIndex:put |
Put log index |
None |
lts:sqlalarmrules:put |
Modify alarm options |
None |
lts:logs:upload |
Upload logs |
None |
lts:agentDetails:list |
List agent diagnostic log |
None |
lts:agentsConf:put |
Put agent conf |
None |
lts:logstreams:list |
Check logstream resources |
None |
lts:subscriptions:get |
Get subscription |
None |
lts:disStreams:list |
Query DIS pipe |
None |
lts:groupTopics:put |
Create log group and log topic |
None |
lts:resourceInstance:list |
Query resource instance |
None |
lts:transfers:list |
List transfers |
None |
lts:topics:get |
Get log topic |
None |
lts:agentsConf:delete |
Delete agent conf |
None |
lts:agentEcs:list |
List agent ecs |
None |
lts:indiceLogs:list |
Search indiceLogs |
None |
lts:topics:list |
List log topic |
None |
