Managing Security Reports
This section describes how to manage security reports, including enabling, disabling, modifying, and deleting security reports.
Enabling/Disabling the Security Report Function
- In the navigation pane on the left, click
and choose . The Dashboard page will be displayed. - (Optional) Switch to another firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation tree on the left, choose . The Security Report page is displayed.
- Toggle on or off the switch in the upper right corner of the target report to change the status.
: enabled
: disabled
Modifying a Security Report
- Click Edit in the lower right corner of the target report to modify the report information.
Table 1 Parameters of the security report template Parameter
Report Name
Name of a security report
Report Type
- Daily
Statistical period: 00:00:00 to 24:00:00 every day
A report will be sent to the recipients the day after it is generated.
- Weekly
Statistical period: 00:00:00 on Monday to 24:00:00 on Sunday
A report will be sent to the recipients at the specified time after it is generated.
Report Schedule
When Report Type is set to Daily or Weekly, you need to set the report sending time. By default, the log report of the previous statistical period is sent.
Recipient Group
Select a topic from the drop-down list to configure the endpoints for receiving the log report.
- Daily
- Click OK. A security report is created.
Deleting a Security Report
- Click Delete in the lower right corner of the target report to delete the report.
