Viewing a Predefined Service Group
CFW provides predefined service groups, including Web Service, Database, and Remote Login and Ping, suitable for protecting web services, databases, and servers, respectively.
You can only view predefined service groups, but cannot add services to it, or modify or delete it.
- In the navigation pane on the left, click
and choose . The Dashboard page will be displayed.
- (Optional) Switch to another firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation pane, choose .
- Click the Service Groups tab. Click the Pre-defined Service Groups tab and click the name of a service group. On the details page that is displayed, view the service group information.
