Viewing Protection Information Using the Policy Assistant
After a protection policy is configured, you can use the policy assistant to check policy hits and adjust policies.
- In the navigation pane on the left, click
and choose . The Dashboard page will be displayed.
- (Optional) Switch to another firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation pane, choose .
- View statistics about the protection rules of a firewall instance.
- Policy Dashboard: Number of accesses that hit policies (protection rules, blacklist, and whitelist), numbers of allowed and blocked accesses, and the allow and block policies that were frequently hit within a specified time range.
- Policy Hits: Hits of a rule within a specified time range.
- Visualizations: Top 5 items ranked by certain parameters regarding blocked attacks within a specified time range. For more information, see Table 1. You can click a record to view policy matching details. For more information, see Table 2.
Table 1 Policy assistant statistics parameters Parameter
Top Policies By Hits
Policies that match and block traffic.
Top Blocked Outbound IP Addresses
Blocked outbound IP addresses. You can click Source or Destination to view the source or destination IP addresses.
Top Blocked Inbound IP Addresses
Blocked inbound IP addresses. You can click Source or Destination to view the source or destination IP addresses.
Top Blocked Destination Ports
Blocked destination ports. You can click Outbound or Inbound to view ports in the corresponding direction.
Top Blocked IP Address Regions
Regions of blocked IP addresses. You can click Destination of outbound access or Source of inbound access to check IP addresses.
- Inactive Policies: Policies that have not been hit or enabled for more than a week, a month, three months, or six months. You are advised to modify or delete the policies in a timely manner.
