Managing Protection Rules
This section describes the protection rule parameters page and how to edit, copy, and delete a protection rule.
The default priority of the copy of a protection rule is 1 (highest priority).
Viewing Protection Rules
- In the navigation pane on the left, click
and choose . The Dashboard page will be displayed.
- (Optional) Switch to another firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation pane, choose Click the Internet Borders or Inter-VPC Borders tab.
. The Access Policies page is displayed.
Table 1 Protection rule parameters Parameter
Priority
Priority of the rule.
NOTE:A smaller value indicates a higher priority.
Name/Rule ID
Custom rule name and ID
Rule Type
Protection type of the rule. It can be an EIP or NAT rule.
Direction
Traffic direction of the protection rule.
Source
Source of data packets in the access traffic.
Destination
Destination of data packets in the access traffic.
Service
- Its value can be TCP, UDP, ICMP, or Any.
- Source Port: Source ports to be allowed or blocked. You can configure a single port or consecutive port groups (example: 80-443).
- Destination Port: Destination ports to be allowed or blocked.
Action
- Allow: Allow the traffic to pass through the firewall.
- Block: Block the traffic from passing through the firewall.
Hits
Total number of actions that have been triggered by the rule (since the last reset). For details, see Access Control Logs.
Status
Status of the rule. It can be enabled or disabled.
Tags
Tag of a rule.
- (Optional) Select a direction and a protocol type from the drop-down list boxes.
Editing a Protection Rule
- In the navigation pane, choose .
- In the row of a rule, click Edit in the Operation column.
- In the displayed Edit Rule dialog box, modify the rule parameters.
- Click OK.
Copying a Protection Rule
- In the row of a rule, choose More > Copy in the Operation column.
- Modify parameters and click OK. The default priority of the new protection rule is 1 (highest priority).
Deleting a Rule
- In the row of a rule, choose More > Delete in the Operation column.
- In the Delete Rule dialog box, click OK.
Deleted rules cannot be restored. Exercise caution when performing this operation.
