Checking the Dashboard
On the Dashboard page, you can view the basic information, overall protection capabilities, and statistics of firewall instances to learn about the security status and traffic of cloud assets at any time.
VPC border protection details can be viewed only after a VPC border firewall is configured.
- In the navigation pane on the left, click
and choose . The Dashboard page will be displayed.
- (Optional) Switch or view firewall instances.
- Switch to another firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
- View firewall instance information: Click Firewall List in the upper right corner. For details about parameters, see Firewall instance information.
Table 1 Firewall instance information Parameter
Firewall Name/ID
Name and ID of the firewall.
Status
Firewall status.
Edition
Edition of a firewall.
Available EIP Protection Quota
Maximum number of EIPs that can be protected by the firewall.
Peak Traffic Protection
Maximum peak traffic that can be protected by the firewall.
Billing Mode
Billing mode of the current firewall.
Enterprise Project
Enterprise project that the firewall belongs to.
Operation
Check instance details.
- In the Resource Protection Overview area, view the protection status of all cloud resources (EIPs and VPCs) in the current region under the current account.
- View firewall instance information.
Table 2 describes the parameters in the Firewall Details area on the right part of the page.
Table 2 Firewall instance details Parameter
Basic Information
Version
Firewall edition. Standard and professional editions are supported.
Firewall Name
Firewall instance name. You can click
to change the name.
Firewall ID
Firewall instance ID.
Status
Firewall status. It takes about 5 minutes to update the firewall status after purchase or unsubscription.
Enterprise Project
Flavor
Number of EIPs protected by the current firewall instance.
Available VPC Protection Quotas
Total number of VPCs that can be protected by the current firewall instance.
CFW instance
Firewall instance specifications.
Used/Available Protection Rules
Number of created protection rules/Total number of protection rules that can be created under a firewall instance.
Other Information
Billing Mode
Billing mode.
Tags
Configure tags to identify firewalls so that you can classify and trace firewall instances.
- On the Operations Dashboard page, view the overall protection data of cloud resources.
Click the Internet Boundaries or Inter-VPC Borders tab to view the corresponding overall protection data.
In the upper right corner, change the query range.- View the blocking results of access control policies and the maximum inbound and outbound traffic.
- Traffic Trend displays the inbound, outbound, and overall traffic trends..
Table 3 Values Time Range
Average
Maximum
Last 1 hour
Average value within every minute
Maximum value within every minute
Last 24 hours
Average value within 5 minutes
Maximum value within 5 minutes
Last 7 days
Average value within one hour
Maximum value within one hour
Data is updated in real time based on traffic statistics.
- Attacks: View the traffic blocked or allowed by intrusion prevention.
- Access Control: View the traffic blocked or allowed by access control policies.
