Why Does Add-on Installation Fail and Prompt "The release name is already exist"?
Symptom
When an add-on fails to be installed, the error message "The release name is already exist" is returned.
Possible Cause
The add-on release record remains in the Kubernetes cluster. Generally, it is because the cluster etcd has backed up and restored the add-on, or the add-on fails to be installed or deleted.
Solution
Use kubectl to connect to the cluster and manually clear the Secret and Configmap corresponding to add-on release. The following uses autoscaler add-on release as an example.
- Connect to the cluster using kubectl, and run the following command to view the Secret list of add-on releases:
kubectl get secret -A |grep cceaddon
The Secret name of an add-on release is in the format of sh.helm.release.v1.cceaddon-{add-on name}.v*. If there are multiple release versions, you can delete their Secrets at the same time.
- Run the release secret command to delete the Secrets.
Example:
kubectl delete secret sh.helm.release.v1.cceaddon-autoscaler.v1 sh.helm.release.v1.cceaddon-autoscaler.v2 -nkube-system
- If the add-on is created when Helm v2 is used, CCE automatically bumps the v2 release in Configmaps to v3 release in Secrets when viewing the add-ons and their details. The v2 release in the original Configmap is not deleted. Run the following command to view the ConfigMap list of add-on releases:
kubectl get configmap -A | grep cceaddon
The ConfigMap name of an add-on release is in the format of cceaddon-{add-on name}.v*. If there are multiple release versions, you can delete their ConfigMaps at the same time.
- Run the release configmap command to delete the ConfigMaps.
Example:
kubectl delete configmap cceaddon-autoscaler.v1 cceaddon-autoscaler.v2 -nkube-system
Deleting resources in kube-system is a high-risk operation. Ensure that the command is correct before running it to prevent resources from being deleted by mistake.
- On the CCE console, install add-on and then uninstall it. Ensure that the residual add-on resources are cleared. After the uninstall is complete, install the add-on again.
When installing the add-on for the first time, you may find it abnormal after the installation due to the residual resources of the previous add-on release, which is normal. In this case, you can uninstall the add-on on the console to ensure that the residual resources are cleared and the add-on can run properly after being installed again.
