Help Center/ Cloud Container Engine/ User Guide (Ankara Region)/ FAQs/ Networking/ Network Planning/ How Can I Configure a Security Group Rule in a Cluster?
CCE is a universal container platform. Its default security group rules apply to common scenarios. When a cluster is created, a security group is automatically created for the master node and worker node, separately. The security group name of the master node is {Cluster name}-cce-control-{Random ID}, and the security group name of the worker node is {Cluster name}-cce-node-{Random ID}.
You can log in to the management console, choose Service List > Networking > Virtual Private Cloud. On the page displayed, choose Access Control > Security Groups in the navigation pane, locate the security group of the cluster, and modify the security group rules as required.
The default security group rules of the clusters using different networks are as follows:
NOTICE:
  • Modifying or deleting security group rules may affect cluster running. Exercise caution when performing this operation. If you need to modify security group rules, do not modify the rules of the port on which CCE running depends.
  • When adding a new security group rule to a cluster, ensure that the new rule does not conflict with the original rules. Otherwise, the original rules may become invalid, affecting the cluster running.
Security Group Rules of a Cluster Using a VPC Network
Security group of worker nodes
A security group named {Cluster name}-cce-node-{Random ID} is automatically created for worker nodes in a cluster. For details about the default ports, see Table 1.
Table 1 Default ports in the security group for worker nodes that use a VPC network
Direction
Port
Default Source Address
Modifiable
Modification Suggestion
Inbound rules
All UDP ports
VPC CIDR block
Allow access between worker nodes and between the worker nodes and master nodes.
No
N/A
All TCP ports
All ICMP ports
Security group of the master node
Used for the master node to access worker nodes.
No
N/A
TCP port range: 30000 to 32767
All IP addresses: 0.0.0.0/0
Allow access from NodePort.
Yes
These ports must permit requests from VPC, container, and ELB CIDR blocks.
UDP port range: 30000 to 32767
All
Container CIDR block
Used for mutual access between nodes and containers.
No
N/A
All
Used for mutual access between worker nodes.
No
N/A
TCP port 22
Port that allows remote access to Linux ECSs using SSH.
Recommended
N/A
Outbound rule
All
Allow traffic on all ports by default. You are advised to retain this setting.
Yes
If you want to harden security by allowing traffic only on specific ports, remember to allow such ports. For details, see Hardening Outbound Rules.
A security group named {Cluster name}-cce-control-{Random ID} is automatically created for the master node. For details about the default ports, see Table 2.
Table 2 Default ports in the security group for the master node that uses a VPC network
Direction
Port
Modifiable
Inbound rules
TCP port 5444
VPC CIDR block
Allow access from kube-apiserver, which provides lifecycle management for Kubernetes resources.
No
N/A
TCP port 5444
TCP port 9443
VPC CIDR block
Allow the network add-on of the worker nodes to access master nodes.
No
N/A
TCP port 5443
Allow kube-apiserver of the master node to listen to the worker nodes.
Recommended
The port must allow traffic from the CIDR blocks of the VPC, container, and the control plane of the hosted service mesh.
TCP port 8445
VPC CIDR block
Allow the storage add-on of the worker nodes to access master nodes.
No
N/A
All
IP addresses of this security group
Allow traffic from all IP addresses of this security group.
No
N/A
Outbound rule
All
No
N/A
Security Group Rules of a Cluster Using the Tunnel Network
A security group named {Cluster name}-cce-node-{Random ID} is automatically created for worker nodes in a cluster. For details about the default ports, see Table 3.
Table 3 Default ports in the security group for worker nodes that use a tunnel network
Direction
Port
Modifiable
Inbound rules
UDP port 4789
Allow access between containers.
No
N/A
TCP port 10250
CIDR block of the master node
Allow master nodes to access kubelet on worker nodes, for example, by running kubectl exec {pod}.
No
N/A
Yes
TCP port 22
Recommended
N/A
All
No
N/A
Outbound rule
All
Yes
A security group named {Cluster name}-cce-control-{Random ID} is automatically created for the master node. For details about the default ports, see Table 4.
Table 4 Default ports in the security group for the master node that uses a tunnel network
Direction
Port
Modifiable
Inbound rules
UDP port 4789
No
N/A
TCP port 5444
VPC CIDR block
No
N/A
TCP port 5444
TCP port 9443
VPC CIDR block
No
N/A
TCP port 5443
Recommended
TCP port 8445
VPC CIDR block
No
N/A
All
No
N/A
Outbound rule
All
No
N/A
By default, all security groups created by CCE allow all the outbound traffic. You are advised to retain this configuration. To harden outbound rules, ensure that the ports listed in the following table are enabled.
Table 5 Minimum configurations of outbound security group rules for worker nodes
Port
Allowed CIDR
UDP port 53
DNS server of the subnet
Allow traffic on the port for domain name resolution.
UDP port 4789 (required only for clusters that use the tunnel networks)
All IP addresses
TCP port 5443
TCP port 5444
CIDR blocks of the VPC and container
TCP port 6443
None
TCP port 8445
VPC CIDR block
TCP port 9443
VPC CIDR block
All ports
198.19.128.0/17
Allow worker nodes to access the VPC Endpoint (VPCEP) service.
UDP port 123
Public service CIDR block, which can be obtained from the administrator
Allow worker nodes to access the internal NTP server.
TCP port 443
Allow worker nodes to access OBS over internal networks to pull the installation package.
TCP port 6443
Allow worker nodes to report that the worker nodes are installed.
