Implementing Sticky Session Through Load Balancing
Concepts
Session persistence is one of the most common while complex problems in load balancing.
Session persistence is also called sticky sessions. After the sticky session function is enabled, requests from the same client are distributed to the same backend ECS by the load balancer for better continuity.
In load balancing and sticky session, connection and session are two key concepts. When only load balancing is concerned, session and connection refer to the same thing.
Simply put, if a user needs to log in, it can be regarded as a session; otherwise, a connection.
The sticky session mechanism fundamentally conflicts with the basic functions of load balancing. A load balancer forwards requests from clients to multiple backend servers to avoid overload on a single server. However, sticky session requires that some requests be forwarded to the same server for processing. Therefore, select a proper sticky session mechanism based on the application environment.
Layer-4 Load Balancing (Service)
- Service Affinity of the Service is set to Node level (that is, the value of the externalTrafficPolicy field of the Service is Local).
- Enable the source IP address-based sticky session in the load balancing configuration of the Service.
apiVersion: v1 kind: Service metadata: name: svc-example namespace: default annotations: kubernetes.io/elb.class: union kubernetes.io/elb.id: 56dcc1b4-8810-480c-940a-a44f7736f0dc kubernetes.io/elb.lb-algorithm: ROUND_ROBIN kubernetes.io/elb.session-affinity-mode: SOURCE_IP spec: selector: app: nginx externalTrafficPolicy: Local ports: - name: cce-service-0 targetPort: 80 nodePort: 32633 port: 80 protocol: TCP type: LoadBalancer - Anti-affinity is enabled for the backend application corresponding to the Service.
Layer-7 Load Balancing (Ingress)
In layer-7 load balancing, sticky session based on HTTP cookies and app cookies can be enabled. To enable such sticky session, the following conditions must be met:
- The application (workload) corresponding to the ingress is enabled with workload anti-affinity.
- Node affinity is enabled for the Service corresponding to the ingress.
- Create an Nginx workload.
Set the number of pods to 3 and set the podAntiAffinity.
kind: Deployment apiVersion: apps/v1 metadata: name: nginx namespace: default spec: replicas: 3 selector: matchLabels: app: nginx template: metadata: labels: app: nginx spec: containers: - name: container-0 image: 'nginx:perl' resources: limits: cpu: 250m memory: 512Mi requests: cpu: 250m memory: 512Mi imagePullSecrets: - name: default-secret affinity: podAntiAffinity: # Pod anti-affinity. requiredDuringSchedulingIgnoredDuringExecution: - labelSelector: matchExpressions: - key: app operator: In values: - nginx topologyKey: kubernetes.io/hostname - Creating a NodePort Service
Configure the sticky session in a Service. An ingress can connect to multiple Services, and each Service can have different sticky sessions.
apiVersion: v1 kind: Service metadata: name: nginx namespace: default annotations: kubernetes.io/elb.lb-algorithm: ROUND_ROBIN kubernetes.io/elb.session-affinity-mode: HTTP_COOKIE # HTTP cookie type. kubernetes.io/elb.session-affinity-option: '{"persistence_timeout":"1440"}' # Session stickiness duration, in minutes. The value ranges from 1 to 1440. spec: selector: app: nginx ports: - name: cce-service-0 protocol: TCP port: 80 targetPort: 80 nodePort: 32633 # Node port number. type: NodePort externalTrafficPolicy: Local # Node-level forwarding.You can also select APP_COOKIE.
apiVersion: v1 kind: Service metadata: name: nginx namespace: default annotations: kubernetes.io/elb.lb-algorithm: ROUND_ROBIN kubernetes.io/elb.session-affinity-mode: APP_COOKIE # Select APP_COOKIE. kubernetes.io/elb.session-affinity-option: '{"app_cookie_name":"test"}' # Application cookie name. ... - Create an ingress and associate it with a Service.
apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/elb.class: union kubernetes.io/elb.port: '80' kubernetes.io/elb.autocreate: '{ "type":"public", "bandwidth_name":"cce-bandwidth-test", "bandwidth_chargemode":"traffic", "bandwidth_size":1, "bandwidth_sharetype":"PER", "eip_type":"5_bgp" }' spec: rules: - host: 'www.example.com' http: paths: - path: '/' backend: service: name: nginx #Service name port: number: 80 property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cce - Log in to the ELB console, access the load balancer details page, and check whether the sticky session feature is enabled.
