Help Center/ Cloud Container Engine/ User Guide (Ankara Region)/ Network/ Ingresses/ LoadBalancer Ingresses/ Configuring URL Redirection for a LoadBalancer Ingress
Ingress can redirect specific access requests to a specified path. The following is an example of YAML file for configuring an ingress redirection rule. In this example, the request for accessing example.com is redirected to example.com/testa and status code 301 is returned.
  • The advanced forwarding policy of LoadBalancer ingresses is available only to dedicated load balancers.
  • The advanced forwarding policy of LoadBalancer ingresses is available only in clusters of version v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later.
Configuring a Rule for Redirecting an Ingress to a URL Using YAML
An ingress can be redirected to a URL using annotations. Example:
kind: Ingress
  namespace: default
  annotations:
    kubernetes.io/elb.id: df76342f-e898-402a-bac8-bde5bf974da8
    kubernetes.io/elb.class: performance
    kubernetes.io/elb.port: '80'
    kubernetes.io/elb.redirect-url: https://example.com/testa        # Information about the redirection to a URL
    kubernetes.io/elb.redirect-url-code: '301'     # Code returned after the ingress is redirected to a URL
  rules:
    - host: "example.com"
      http:
        paths:
          - path: /
            backend:
              service:
                port:
                  number: 8888
            property:
  ingressClassName: cce
Table 1 Key parameters
Mandatory
Type
Yes
String
URL for redirection
Format: A valid URL must start with http:// or https://, for example, https://example.com/.
Parameter: This configuration takes effect on all forwarding rules of a single ingress. After the configuration is deleted, the target URL redirection rule will be automatically cleared.
Either this annotation or the annotation of a grayscale release can be configured.
No
String
Code returned after an ingress is redirected to a URL.
Format: The return code can be 301, 302, 303, 307, or 308.
Parameter: The default value is 301.
Use curl to verify the redirection, where ${ELB_IP} is the IP address accessed by the target ingress.
# curl -I -H "Host:example.com" {$ELB_IP}
The access path will be redirected to example.com/testa.
HTTP/1.1 301 Moved Permanently
Date: Thu, 07 Mar 2024 11:04:31 GMT
Content-Type: text/html
Content-Length: 134
Connection: keep-alive
Server: elb
