On this page
GPU Add-on
Updated on 2024-12-18 GMT+08:00
Check Items
The GPU add-on is involved in the upgrade, which may affect the GPU driver installation during the creation of a GPU node.
Solution
The GPU add-on driver needs to be configured by yourself. Check the compatibility between the GPU add-on and the GPU driver. It is a good practice to verify the upgrade of the GPU driver to the target version in the test environment, configure the current GPU driver, and check whether the created GPU node can run properly.
Perform the following operations to check the upgrade of the GPU driver to the target version and current driver configuration of GPU add-on:
  1. Log in to the CCE console and click Add-ons to view the GPU add-on.
    gpu-beta is the same as gpu-device-plugin. gpu-beta is renamed gpu-device-plugin in versions later than 2.0.0.
  2. Click Upgrade of the add-on to view the target version and driver configuration of the add-on.
  3. Verify the upgrade of the GPU driver to the target version in the test environment, configure the current GPU driver, and check whether the created GPU node can run properly.
    If the GPU add-on and the GPU driver are incompatible, install the driver of a later version. If necessary, contact technical support.
