Updated on 2024-12-18 GMT+08:00
Patch Version Release Notes
Version 1.28
Table 1 Release notes for the v1.28 patch
CCE Cluster Patch Version
Kubernetes Version
Feature Updates
Optimization
Vulnerability Fixing
v1.28.6-r4
v1.28.8
The stability of ELB has been improved during upgrades that span across multiple versions.
Fixed some security issues.
v1.28.2-r0
v1.28.3
None
None
v1.28.1-r4
v1.28.3
None
None
Fixed CVE-2024-21626 issues.
v1.28.1-r0
v1.28.3
CCE clusters of v1.28 are released for the first time. For more information, see Kubernetes 1.28 Release Notes.
  • The prefix and suffix of a node name can be customized in node pools.
  • LoadBalancer ingresses support gRPC.
  • LoadBalancer Services allow you to specify a private IP address for a load balancer during Service creation using YAML.
None
None
Version 1.27
In CCE v1.27 and later versions, all nodes support only the containerd container engine.
Table 2 Release notes for the v1.27 patch
Kubernetes Version
Feature Updates
Optimization
v1.27.8-r4
v1.27.12
v1.27.3-r4
v1.27.4
None
None
v1.27.2-r0
v1.27.2
  • Volcano supports node pool affinity scheduling.
  • Volcano supports workload rescheduling.
None
v1.27.1-r10
v1.27.2
None
Optimized the events generated during node pool scaling.
v1.27.1-r0
v1.27.2
CCE clusters of v1.27 are released for the first time. For more information, see Kubernetes 1.27 Release Notes.
  • Both soft eviction and hard eviction are supported in node pool configurations.
None
None
Version 1.25
All nodes in the CCE clusters of version 1.25, except the ones running EulerOS 2.5, use containerd by default.
Table 3 Release notes for the v1.25 patch
Kubernetes Version
Feature Updates
Optimization
v1.25.11-r4
v1.25.16
v1.25.6-r4
v1.25.10
None
None
v1.25.5-r0
v1.25.5
None
v1.25.4-r10
v1.25.5
None
v1.25.4-r0
v1.25.5
None
v1.25.3-r10
v1.25.5
The timeout interval can be configured for a load balancer.
High-frequency parameters of kube-apiserver are configurable.
v1.25.1-r0
v1.25.5
CCE clusters of v1.25 are released for the first time. For more information, see Kubernetes 1.25 Release Notes.
None
None
