On this page
Overview
Auto scaling is a service that automatically and economically adjusts service resources based on your service requirements and configured policies.
Context
More and more applications are developed based on Kubernetes. It becomes increasingly important to quickly scale out applications on Kubernetes to cope with service peaks and to scale in applications during off-peak hours to save resources and reduce costs.
In a Kubernetes cluster, auto scaling involves pods and nodes. A pod is an application instance. Each pod contains one or more containers and runs on a node (VM or bare-metal server). If a cluster does not have sufficient nodes to run new pods, add nodes to the cluster to ensure service running.
In CCE, auto scaling is used for online services, large-scale computing and training, deep learning GPU or shared GPU training and inference, periodic load changes, and many other scenarios.
Auto Scaling in CCE
CCE supports auto scaling for workloads and nodes.
  • Workload scaling: Auto scaling at the scheduling layer to change the scheduling capacity of workloads. For example, you can use the HPA, a scaling component at the scheduling layer, to adjust the number of replicas of an application. Adjusting the number of replicas changes the scheduling capacity occupied by the current workload, thereby enabling scaling at the scheduling layer.
  • Node scaling: Auto scaling at the resource layer. When the planned cluster nodes cannot allow workload scheduling, ECS resources are provided to support scheduling.
Components
Workload scaling components are described as follows:
Table 1 Workload scaling components
Type
Component Name
Component Description
Reference
HPA
Kubernetes Metrics Server
A built-in component of Kubernetes, which enables horizontal scaling of pods. It adds the application-level cooldown time window and scaling threshold functions based on the HPA.
HPA Policies
CustomedHPA
CCE Advanced HPA
An enhanced auto scaling feature, used for auto scaling of Deployments based on metrics (CPU usage and memory usage) or at a periodic interval (a specific time point every day, every week, every month, or every year).
CustomedHPA Policies
Prometheus
Cloud Native Cluster Monitoring
An open-source system monitoring and alarm framework, which collects public metrics (CPU usage and memory usage) of kubelet in the Kubernetes cluster.
CronHPA
CCE Advanced HPA
CronHPA can scale in or out a cluster at a fixed time. It can work with HPA policies to periodically adjust the HPA scaling scope, implementing workload scaling in complex scenarios.
CronHPA Policies
Node scaling components are described as follows:
Table 2 Node scaling components
Component Name
Application Scenario
Reference
CCE Cluster Autoscaler
An open source Kubernetes component for horizontal scaling of nodes, which is optimized by CCE in scheduling, auto scaling, and costs.
Online services, deep learning, and large-scale computing with limited resource budgets
Creating a Node Scaling Policy
