Failed to Cancel Backup Sharing
Symptom
When you cancel the backup sharing, the system prompts a message indicating that the canceling failed.
Troubleshooting
Possible causes are listed here in order of their probability.
If the fault persists after you have ruled out one cause, move on to the next one.
Possible Cause |
Solution |
The shared backup was used to create images. |
Delete the images and then delete the shared backup. For details, see section "Deleting Images" in the Image Management Service User Guide. |
The status of the shared backup failed to be updated. |
Try again or contact technical support. |
