Migrating Resources from a Vault
You can migrate vault resources when enterprise services change, and the original vault no longer aligns with the new service scale or required specifications.
Migrating a resource means that you dissociate a resource from a vault and then associate it to another vault. All backups of the resource will be migrated to the destination vault.
- Resources can be migrated only when the source and destination vaults are in the Available or Locked state.
- Resources can be migrated only when no task is being executed in the source and destination vaults.
- The remaining capacity of the destination vault must be greater than the size of the resource backups to be migrated.
- Cross-account resource migration is currently not supported.
- The source and destination vaults must be in the same region.
- The source and destination vaults for resource migration must be of the same types. For example, resources in a server backup vault can be migrated to another server backup vault, but cannot be migrated to another disk backup vault.
- Log in to the CBR console.
- In the upper left corner, click
and select a region. - Click
and choose Storage > Cloud Backup and Recovery.
- Find the target vault and click its name. In this example, we will be using the Cloud Server Backups page to illustrate the process.
- Click the Associated Servers tab. Find the target server and click Migrate in the Operation column.
- Select the destination vault and click OK.
- View the migration progress on the Tasks page. If Status changes to Successful, the resource has been migrated.
- Go to the destination vault to confirm that the resource has been associated and all its backups have been migrated.
