On this page
Show all
Creating an Alarm Rule
Updated on 2024-04-19 GMT+08:00
Cloud Eye allows you to use alarm templates to create alarm rules, making it easy and convenient to add or modify alarm rules for resources or cloud services, especially for a large number of resources and cloud services.
You can use a default alarm template to create an alarm rule for a cloud service resource.
You can create alarm rules for CBR.
  2. Under Management & Deployment, select Cloud Eye. In the navigation pane on the left, choose Alarm Management > Alarm Rules.
  3. On the displayed page, click Create Alarm Rule in the upper right corner.
  4. On the displayed Create Alarm Rule page, configure the parameters.
    1. Set Name and Description.
      Parameters for configuring the rule name and description
      Example Value
      Name
      Name of the alarm rule. The system generates a random name, which you can modify.
      alarm-cgnw
      Alarm rule description. This parameter is optional.
    2. Configure alarm content parameters.
      • If you select Cloud Backup and Recovery for Resource Type, vaults are monitored with two metrics. Table 1 describes the parameters.
        Table 1 Parameters
        Example Value
        Resource Type
        Cloud Backup and Recovery is selected in this example.
        Dimension
        Monitoring dimension. By default, monitoring is performed by vault.
        Vault
        Monitoring Scope
        Choose the vaults you want to monitor from the list.
        vault-56f8
        Method
        You can create an alarm rule by using the template or manually creating it.
        If you set Monitoring Scope to Specific resources, you can set Method to Use template.
        Use template
        Template
        Template to be used.
        Alarm Policy
        Policy for triggering an alarm.
        If you set Resource Type to a specific cloud service, the alarm policy takes effect periodically. If you set Resource Type to Event Monitoring, the alarm policy takes effect based on specific events.
        Currently, the following CBR monitoring metrics are supported:
        • Vault Usage
        • Used Vault Size
        Alarm Severity
        Alarm severity, which can be Critical, Major, Minor, or Informational.
        Major
      • If you set Resource Type to Event Monitoring, CBR resources are monitored based on specific events. Table 1 describes the parameters.
        Table 2 Parameters
        Example Value
        Resource Type
        Event Monitoring is selected in this example.
        Event Monitoring
        Dimension
        Metric dimension of the selected resource type.
        System event
        Monitoring Scope
        Monitoring scope for event monitoring.
        Default value: All resources
        Method
        Select Configure manually.
        Configure manually
        Alarm Policy
        Table 3 lists the supported CBR events that trigger alarms.
        Table 3 CBR events that trigger alarms
        Event Source
        Event Name
        Alarm Severity
        Solution
        Impact
        CBR
        Failed to create the backup.
        Critical
        Backup creation failed.
        Manually create a backup or contact the administrator.
        Data may be lost.
        Failed to restore the resource using a backup.
        Critical
        Resource restoration using a backup failed.
        Restore the resource using another backup or contact the administrator.
        Data may be lost.
        Failed to delete the backup.
        Critical
        Backup deletion failed.
        Try again later or contact the administrator.
        Charging may be abnormal.
        Failed to delete the vault.
        Critical
        Vault deletion failed.
        Replication failure
        Critical
        Backup replication failed.
        Data may be lost.
        The backup is created successfully.
        Major
        Backup created.
        None
        None
        Resource restoration using a backup succeeded.
        Major
        Check that data is successfully restored.
        None
        The backup is deleted successfully.
        Major
        Backup deleted.
        None
        None
        The vault is deleted successfully.
        Major
        Vault deleted.
        None
        None
        Replication success
        Major
        Backup replicated.
        None
        None
        You can change the alarm severity as needed.
    3. Configure alarm notifications.
      Table 4 Parameters for configuring alarm notifications
      Example Value
      Alarm Notification
      Whether to notify users when alarms are triggered. Notifications can be sent by email or text message, or through HTTP/HTTPS request to servers.
      You can enable (recommended) or disable Alarm Notification.
      Notification Window
      Cloud Eye sends notifications only within the notification window specified in the alarm rule.
      If Notification Window is set to 00:00-8:00, Cloud Eye sends alarm notifications only within 00:00-8:00.
      Notification Object
      The name of the topic the alarm notification is to be sent to.
      If you enable alarm notification, you need to select a topic. If no desirable topics are available, create one and subscribe to it first. For details about how to create a topic, see the Simple Message Notification User Guide.
      Trigger Condition
      The condition for triggering the alarm notification. You can select Generated alarm, Cleared alarm, or both.
    4. Click Create.
After the alarm rule is created, if the metric data reaches the specified threshold or a CBR event happens, Cloud Eye immediately informs you that an exception has occurred. For details, see the Cloud Eye User Guide.
