Updated on 2025-11-18 GMT+08:00
Task Management
You can view tasks in the task list, which shows policy-driven tasks that have been executed over the past 30 days.
There is at least one task.
Viewing a Task
- Log in to the CBR console.
- Click
in the upper left corner and select a region. - Choose Storage > Cloud Backup and Recovery > Tasks.
- Filter tasks by task type, task status, task ID, resource ID, resource name, vault ID, vault name, or time.
- Click
in front of the task to view the task details.
If a task fails, you can view the failure cause in the task details.
