Help Center/
Cloud Backup and Recovery/
User Guide (Ankara Region)/
Policy Management/
Removing a Policy from a Vault
Updated on 2024-04-19 GMT+08:00
If you no longer need automatic backup for a vault, remove the policy from the vault.
A policy has been applied to the vault.
- Log in to the CBR console.
- Click
in the upper left corner and select a region. - Click
and choose Storage > Cloud Backup and Recovery. Select a backup type from the left navigation pane.
- Find the target vault and click the vault name to view its details.
- In the Policies area, click Remove Policy.
- If a policy is removed when a backup task is being executed for a resource in the vault, the backup task will continue and backups will be generated.
- After a policy is removed, backups retained by Time period will expire based on the retention rule, but backups retained by Backup quantity will not. You need manually delete unwanted backups.
- Click Yes.
Tasks will no longer be executed based on this policy for the vault.
Parent topic: Policy Management
