Sharing a Backup
You can share server or disk backups with projects of other accounts. Shared backups can be used to create servers or disks.
Context
For sharers:
- Backups can only be shared among projects of accounts in the same region. They cannot be shared across regions.
- When a sharer deletes a shared backup, the backup will also be deleted from the recipient's account, but the disks or servers previously created using the backup will be retained.
For recipients:
- A recipient must have at least one backup vault to store the accepted shared backup, and the vault's remaining space must be greater than the size of the backup to be accepted.
- A recipient can choose to accept or reject a backup sharing request. After accepting the backup, the recipient can use the backup to create servers or disks.
Initiating Backup Sharing
- Log in to the CBR console.
- In the upper left corner, click
and select a region. - Click
and choose Storage > Cloud Backup and Recovery.
- Click the Backups tab and set filter criteria to view the backups.
- Locate the target backup and choose More > Share Backup in the Operation column.
The backup name, server or disk name, backup ID, and backup type are displayed.
- Click the Share Backup tab.
- Enter the account name of the recipient.
- Click Add. The account and project to be added is displayed in the list. You can continue to add accounts. A backup can be shared to a maximum of 10 projects.
- Click OK.
Go back to the backup list, click the backup name to go to the backup details page, and click the Share List tab to view the shared backup.
Accepting the Shared Backup
- Click the Backups tab on the cloud server or disk backup vault page and then click Backups Shared with Me.
- Ensure that the recipient has at least one backup vault before accepting the shared backup. For how to purchase a backup vault, see Step 1: Create a Vault.
- Click Accept. On the displayed page, select the vault used to store the shared backup. Ensure that the vault's remaining capacity is greater than the backup size.
Automatic Association: Determines whether to enable automatic association for the vault. If you select Configure, the vault automatically scans for and associates servers that have not been backed up and performs backup in the next backup period.
- View the shared backup you accepted in the backup list.
Canceling Backup Sharing
- On the cloud server backup page or cloud disk backup page, click the Backups tab and set filter criteria to view the backups.
- Click the Cancel Sharing tab, select the projects you want to cancel sharing, and click OK.
Return to the backup list, click the backup name to go to the backup details page, and click the Share List tab to view the unshared backups.
If the system displays a message indicating that the backup sharing fails to be canceled, rectify the faults by referring to Failed to Cancel Backup Sharing.
