Changing Vault Specifications
Server backup vaults and server replication vaults both have two specifications: those for server backups and those for application-consistent backups.
- Server backups are backups of non-database servers.
- Application-consistent backups are backups of database servers.
If you need to back up database servers, change the specifications of the target vault from server backup to application-consistent backup.
You can only change the specifications of a vault from server backup to application-consistent backup, but not the other way around.
- Log in to the CBR console.
- Click
in the upper left corner and select a region. - Click
and choose Storage > Cloud Backup and Recovery. Select a backup type from the left navigation pane.
- On the Cloud Server Backups page, find the target vault. Choose More > Change Specifications in the Operation column of the vault.
- Application-Consistent Backup is preset for Backup Type. Click Next.
- Click Submit and complete the payment. The system automatically changes the vault specifications.
