Help Center/
Cloud Backup and Recovery/
User Guide (Ankara Region)/
Vault Management/
Expanding Vault Capacity
Updated on 2025-11-18 GMT+08:00
You can expand the size of a vault if its total capacity is insufficient.
- Log in to the CBR console.
- In the upper left corner, click
and select a region. - Click
and choose Storage > Cloud Backup and Recovery.
- Locate the target vault and choose More > Expand Capacity in the Operation column.
- Enter the capacity to be added. The minimum value is 1 GB.
- Click Next. Confirm the settings and click Submit.
- Return to the vault list and check that the capacity of the vault has been expanded.
Parent topic: Vault Management
