Updated on 2025-11-07 GMT+08:00
CBR Concepts
Vault
CBR stores backups of a variety of resources in vaults, which are classified into the following types:
  • Server backup vaults: store backups of non-database servers or database servers. You can associate servers with a vault and apply a backup policy. You can replicate backups in the vault to a replication vault in another region. You can then use the backups for restoration.
  • Disk backup vaults: store only disk backups. You can associate disks with a disk backup vault and apply a backup policy to schedule automatic backups.
Backup
A backup is a copy of a particular chunk of data and is usually stored elsewhere so that it can be used to restore the original data in the event of data loss. It can be generated either manually by a one-off backup task or automatically by a periodic backup task.
A one-off backup task is manually created and is executed only once. Periodic backup tasks are automatically executed based on a user-defined backup policy.
  • A one-off backup is named manualbk_xxxx and can be user- or system-defined.
  • A periodic backup is automatically named autobk_xxxx by CBR.
Backup Policy
A backup policy is a set of rules that define the schedule and retention of backups. After you apply a backup policy to a vault, CBR automatically backs up data and retains backups based on that backup policy.
Cross-region Replication
Replication is the process of replicating backups from one region to another. You can use the replicas in the destination region to create images and provision servers.
You can manually replicate a single cloud server backup. You can also configure replication rules in a policy to periodically replicate backups, including those that have not been replicated or failed to be replicated to the destination region.
For example, if you want to back up a server, select Backup for the vault protection type. If you want to replicate backups of this server to a different region, select Replication for the vault in this different region.
Instant Restore
Instant Restore restores data and creates images from backups, much faster than a normal restore.
Instant Restore is an enhanced function of CBR and requires no additional configuration. After Instant Restore is provided, you take less time to restore server data or create images.
Enhanced Backup
Enhanced backups are backups generated after Instant Restore is provided. Enhanced backups make it faster to restore server data or create images. If Instant Restore Support is Yes in the backup details, the backup is an enhanced backup. Otherwise, the backup is a common backup.
Before providing Instant Restore, CBR generates common backups. After providing Instant Restore, CBR first performs a full backup for each associated resource and then generates enhanced backups. CBR only generates enhanced backups for new resources currently.
For the same resource, an enhanced backup and a common backup have the same backup content and size. They only differ in the restoration speed.
Database Server Backup
There are three types of backups in terms of backup consistency:
  • Inconsistent backup: An inconsistent backup contains data taken from different points in time. This typically occurs if changes are made to your files or disks during the backup.
  • Crash-consistent backup: A crash-consistent backup captures all data on disks at the time of the backup and does not capture data in memory or any pending I/O operations. Although it cannot ensure application consistency, disks are checked by chkdsk upon operating system restart to restore damaged data and undo logs are used by databases to keep data consistent.
  • Application-consistent backup: An application-consistent backup captures data in memory or any pending I/O operations and allows applications to achieve a quiescent and consistent state.
CBR cloud server backup supports both crash-consistent backup and application-consistent backup (also called database server backup). Install the Agent before enabling application-consistent backup to prevent the database server backup from failing.
