Updated on 2025-11-07 GMT+08:00
Application Scenarios
CBR is ideal for data backup and restoration. It can maximize your data security and consistency.
Data Backup and Restoration
You can use CBR to quickly restore data to the latest backup point if any of the following incidents occur:
  • Hacker or virus attacks
  • Accidental deletion
  • Application update errors
  • System breakdown
