Functions
Table 1 lists the functions of CBR.
Before using CBR functions, it is recommended that you learn about basic CBR concepts.
Category |
Function |
Description |
Cloud disk backup |
Manual disk backup |
Cloud disk backup provides snapshot-based backup for EVS disks on servers. You can back up specific disks to protect data on them. |
Cloud disk backup |
Policy-based backup |
You can create, modify, or delete a backup policy. A backup policy defines the schedule and retention for automatic backups. |
Cloud disk backup |
Backup management |
You can set search criteria to quickly find the backups you want to manage. Then you can view their details, share, restore, or delete them if needed. |
Cloud disk backup |
Disk restoration using backups |
When a disk is faulty, or their data is lost, you can use a backup to quickly restore the data. |
Cloud disk backup |
Disk creation using backups |
You can use a disk backup to create a disk that contains the same data as the backup. |
Cloud disk backup |
Sharing a Backup |
You can share a disk backup with other accounts to allow them to use the backup to create disks. |
Cloud server backup |
Manual server backup |
Cloud server backup uses the consistency snapshot technology to protect data for ECSs without the need to install the Agent. You can use CBR to back up an entire server to protect their data. |
Backup management |
You can set search criteria to quickly find the backups you want to manage. Then you can view their details, share, restore, replicate, or delete them if needed. |
Server restoration using backups |
When a server is faulty, or their data is lost, you can use a backup to quickly restore the data. |
Sharing a Backup |
You can share a server backup with other accounts to allow them to use the backup to create servers. |
Image creation using server backups |
You can create images from ECS backups and then use the images to quickly provision ECSs to restore service. |
Database server backup |
Cloud server backup supports application-consistent backup in addition to crash-consistent backup. You can use cloud server backup to back up ECSs running MySQL or SAP HANA databases, because application-consistent backup ensures that the backed-up data is transactionally consistent. |
