month
This function is used to return the month (from January to December) of a specified time.
Syntax
month(string date)
Parameters
Parameter |
Mandatory |
Type |
Description |
date |
Yes |
DATE or STRING |
Date that needs to be processed If the value is of the STRING type, the value must contain at least yyyy-mm-dd and cannot contain redundant strings. The following formats are supported:
Return Values
The return value is of the INT type.
- If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
- If the value of date is NULL, NULL is returned.
Example Code
The value 8 is returned.
select month('2023-08-10 10:54:00');
The value NULL is returned.
select month('20230810');
select month(null);
