tan
This function is used to return the tangent value of a, with input in radians.
Syntax
tan(DOUBLE a)
Parameters
| Parameter | Mandatory | Type | Description |
| a | Yes | DOUBLE, BIGINT, DECIMAL, or STRING | The value can be a float, integer, or string. If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation. |
Return Values
The return value is of the DOUBLE type.
If the value of a is NULL, NULL is returned.
Example Code
The value 0.9999999999999999 is returned.
select tan(pi()/4);
The value NULL is returned.
select tan(null);
