log10
Updated on 2023-10-25 GMT+08:00
This function is used to return the natural logarithm of a given value with a base of 10.
Syntax
log10(DOUBLE a)
Parameters
Table 1 Parameter
Mandatory
Type
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE type.
If the value of a is negative, 0, or NULL, NULL is returned.
Example Code
The value NULL is returned.
select log10(null);
select log10(0);
The value 0.9542425094393249 is returned.
select log10(9);
The value 1 is returned.
select log10(10);
