levenshtein
This function is used to returns the Levenshtein distance between two strings, for example, levenshtein('kitten','sitting') = 3.
Levenshtein distance is a type of edit distance. It indicates the minimum number of edit operations required to convert one string into another.
Syntax
levenshtein(string A, string B)
Parameters
| Parameter | Mandatory | Type | Description |
| A, B | Yes | STRING | String to be entered for calculating the Levenshtein distance |
Return Values
The return value is of the INT type.
Example Code
The value 3 is returned.
SELECT levenshtein('kitten','sitting'); Feedback
