get_json_object
Updated on 2024-09-29 GMT+08:00
This function is used to parse the JSON object in a specified JSON path. The function will return NULL if the JSON object is invalid.
Syntax
get_json_object(string <json>, string <path>)
Parameters
Table 1 Parameters
Mandatory
Type
json
Yes
STRING
Standard JSON object, in the {Key:Value, Key:Value,...} format.
path
Yes
STRING
Path of the object in JSON format, which starts with $. The meanings of characters are as follows:
  • $ indicates the root node.
  • . indicates a subnode.
  • [] indicates the index of an array, which starts from 0.
  • * indicates the wildcard for []. The entire array is returned. * does not support escape.
Return Values
The return value is of the STRING type.
  • If the value of json is empty or in invalid JSON format, NULL is returned.
  • If the value of json is valid and path is specified, the corresponding string is returned.
Example Code
  • Extracts information from the JSON object src_json.json. An example command is as follows:
    jsonString = {"store": {"fruit":[{"weight":8,"type":"apple"},{"weight":9,"type":"pear"}], "bicycle":{"price":19.95,"color":"red"} }, "email":"amy@only_for_json_udf_test.net", "owner":"Tony" }
    Extracts the information of the owner field and returns Tony.
    select get_json_object(jsonString, '$.owner');
    Extracts the first array information of the store.fruit field and returns {"weight":8,"type":"apple"}.
    select get_json_object(jsonString, '$.store.fruit[0]');
    Extracts information about a field that does not exist and returns NULL.
    select get_json_object(jsonString, '$.non_exist_key');
  • Extracts information about an array JSON object. An example command is as follows:
    The value 22 is returned.
    select get_json_object('{"array":[["a",11],["b",22],["c",33]]}','$.array[1][1]');
    The value ["h00","h11","h22"] is returned.
    select get_json_object('{"a":"b","c":{"d":"e","f":"g","h":["h00","h11","h22"]},"i":"j"}','$.c.h[*]');
    select get_json_object('{"a":"b","c":{"d":"e","f":"g","h":["h00","h11","h22"]},"i":"j"}','$.c.h');
    The value h11 is returned.
    select get_json_object('{"a":"b","c":{"d":"e","f":"g","h":["h00","h11","h22"]},"i":"j"}','$.c.h[1]');
  • Extracts information from a JSON object with a period (.). An example command is as follows:
    Create a table.
    create table json_table (id string, json string);
    Insert data into the table. The key contains a period (.).
    insert into table json_table (id, json) values ("1", "{\"city1\":{\"region\":{\"rid\":6}}}");
    Insert data into the table. The key does not contain a period (.).
    insert into table json_table (id, json) values ("2", "{\"city1\":{\"region\":{\"rid\":7}}}");
    Obtain the value of rid. If the key is city1, 6 is returned. Only [''] can be used for parsing because a period (.) is included.
    select get_json_object(json, "$['city1'].region['id']") from json_table where id =1;
    Obtain the value of rid. If the key is city1, 7 is returned. You can use either of the following methods:
    select get_json_object(json, "$['city1'].region['id']") from json_table where id =2;
    select get_json_object(json, "$.city1.region['id']") from json_table where id =2;
  • The json parameter is either empty or has an invalid format. An example command is as follows:
    The value NULL is returned.
    select get_json_object('','$.array[2]');
    select get_json_object('"array":["a",1],"b":["c",3]','$.array[1][1]');
  • A JSON string involves escape. An example command is as follows:
    The value 3 is returned.
    select get_json_object('{"a":"\\"3\\"","b":"6"}', '$.a');
    select get_json_object('{"a":"\'3\'","b":"6"}', '$.a');
  • A JSON object can contain the same key and can be parsed successfully.
    The value 1 is returned.
    select get_json_object('{"b":"1","b":"2"}', '$.b');
  • The result is output in the original sorting mode of the JSON string.
    The value {"b":"3","a":"4"} is returned.
    select get_json_object('{"b":"3","a":"4"}', '$');
