floor
This function is used to round down a to the nearest integer.
Syntax
floor(DOUBLE a)
Parameters
| Parameter | Mandatory | Type | Description |
| a | Yes | DOUBLE, BIGINT, DECIMAL, or STRING | The value can be a float, integer, or string. If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation. |
Return Values
The return value is of the BIGINT type.
If the value of a is NULL, NULL is returned.
Example Code
The value 1 is returned.
select floor(1.2);
The value -2 is returned.
select floor(-1.2);
The value NULL is returned.
select floor(null);
