exp
Updated on 2023-10-25 GMT+08:00
This function is used to return the value of e raised to the power of a.
Syntax
exp(DOUBLE a)
Parameters
Table 1 Parameter
Mandatory
Type
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE type.
If the value of a is NULL, NULL is returned.
Example Code
The value 7.38905609893065 is returned.
select exp(2);
The value 20.085536923187668 is returned.
select exp(3);
The value NULL is returned.
select exp(null);
