datepart
This function is used to calculate the value that meets the specified datepart in date.
Syntax
datepart (string date, string datepart)
Parameters
| Parameter | Mandatory | Type | Description |
| date | Yes | DATE or STRING | Start date The following formats are supported:
| datepart | Yes | STRING | Time unit of the value to be returned This parameter supports the following extended date formats: year, month or mon, day, and hour.
Return Values
The return value is of the BIGINT type.
- If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
- If the value of datepart is NULL, NULL is returned.
Example Code
The value 2023 is returned.
select datepart(date '2023-08-14 17:00:00', 'yyyy');
select datepart('2023-08-14 17:00:00', 'yyyy'); The value 59 is returned.
select datepart('2023-08-14 17:59:59', 'mi') The value NULL is returned.
select datepart(date '2023-08-14', null);
